I installed an SSD as boot device for Windows 7/32 a month ago. For the last days it stops working after being in use for one hour and I have to turn off and on my pc to make work again. Someone told me to set the BIOS to AHCI mode for the SATA port but there is no such setting in the BIOS. Any suggestions? Regards Thomas
I think that you motherboard BIOS can supprot that,
Access your BIOS and look for SATA Mode option, and change it to AHCI
There is no AHCI mode, trust me.
on your BIOS menu goto Advanced->IDE Configuration, and change the value of ATA/IDE Configuration to Enhanced
u can try bios-mods.net for them to unlock features in bios.. it also depends on ich7 chipset.
1.20 2/12/2009 DOS 521.28KB Patch Logitech USB illuminated Keyboard (LZ838BH).
4 x SATAII 3.0 Gb/s connectors (No support for RAID and "Hot Plug" functions)http://www.asrock.co...e...CM-S&o=BIOS
SOURCE: Asrock Motherboard problems with SATA HDD
It is possible that you are trying to use a SATA II HDD in a system that supports SATA. SATA II devices are not backwards compatible usually,
SOURCE: Does Asrock P4VM8 support 500GB SATA hard disks?
near the interface port of the hard drive you have to put a jumper that limit the connection speed from 3.0giga per second to 1.5giga per second, I think that would solve the problem because the hard drive speed goes to 3 giga per second and the motherboard p4vm8 serial ata port can support up to 1.5giga per second.
SOURCE: P4VM800 SATA HDD Problem Plz Help me!!!
Check your user documentation for the hard drive to see if it has a user-accessible jumper that will switch it to 1.5Gb mode. I know that Seagate/Maxtor drives have a jumper they refer to as Force 150 and Western Digital calls their jumper OPT1 Enabled. If this option exists with this hard disk, it should solve your problem.
SOURCE: SATA drive not detected
If you will be loading xp on the new drive,You will just need to press F6 during the setup when ask if you want to install 3rd party driver,and follow the instruction and put the SATA driver disk in when ask.(Even during xp setup It will say SCSI device until all the drivers for it are loaded)
SOURCE: I am using Asrock 775VM800 Motherboard with 80GB
There should be a jumper on the hard drive to select between 3G and 1.5G speeds. It appears that your MB only supports the 1.5G speed.
