When iam saving on pen drive a message will display that cann't copy access denied make sure the disk is not full or write protected and tha the file is not currently is use. please help me soon on [email protected]
If the pen drive got stuck or crack the same message will show. I have a better suggestion to you that you have to format the pen drive first. It helps to remove all bugs and spams from pen drive and it will treat like as a new one.
Pen drive? A USB drive? Have you formatted the drive? Do you have Admin. rights? Remove the USB drive , reboot the computer, insert the usb device, does the computer ID the device and apply a driver? Do you get a popup? Does it show in Computer? What are you trying to copy to the drive?
SOURCE: acer orbicam
Some camera's is needs to be installed to many times!
Try again to uninstall and install it again many times maybe start to work like mine Quick-cam Go!
I have been 9 times installing and its now working.
I think its a matter cd copies and its not installed properly or just stopped to work after couple of days.
SOURCE: ACER SMART failure
SMART means self monitoring and reporting tool, this is the option which performs certain test for the status of hard disk health, if its coming it means condition of your hard disk is not good, its better if you immediately back up your data and replace it, by the way you can also disable this warning through the bios, just disable the smart feature in hard disk
SOURCE: GFI webmonitor download
if you downloaded GFI webmonitor look for the file that has an extension of ".exe".. click that file to extract and install the driver. you don't need to click other files just the .exe only
SOURCE: Acer Aspire One...solid state HD (SSD) keep
Pls Back Up And Re Install Xp Vista Through USB DVD Or Pen Drive Ok Any Problem Pls Contact At [email protected] WWW.RSINFOTECHSYS.BLOGSPOT.COM
SOURCE: How to move data from C to D drive on ACER
Cut and paste, you can do it with the full file rather than the contents.
u should restart your computer
