Tv is about two years old. It is connected to Dish network. It suddenly has lost the picture on Dish, but works with dvd player. It does have sound. I connected to another Dish system at another house and the problem remains the same. Any ideas?
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
my 7 year old "push a buton" and the tv went to snow and showed "TV33-0" on the screen
We have attempted to retrieve the menu and setting without success. The tv is connected to Dish Network but it is not, Apparently, causing the problem.
