Software Issue An intermittent connection could be caused by a software bug or misconfiguration on the tablet itself. Try disconnecting and reconnecting to your network, as this can help to improve signal strength. You should also look to update your device's software if possible, as major tablet manufacturers often release new firmware with the intention of fixing bugs and improving performance. If this does not work, consider backing up your device and resetting it to factory defaults.
SOURCE: setting up a laptop to use its tablet pc functions
XP Pro should run fine on it - I would assume that is what it came with. You may need to download additional drivers from Toshiba. I would check with Toshiba about the pen as well, but without it should still function as a regular laptop.
SOURCE: issues with my Ipad wifi, IPAD wifi not working
According to Apple, the iPad might not automatically rejoin known WiFi networks using third-party routers that are dual-band capable (802.11 b/g and 802.11 n) when each band’s network uses the same name or use different security settings.
Apple’s recommendation? Try creating separate network names for each separate band’s network (ie: add a G to the end of the name of the 802.11 b/g band) and making sure both bands’ networks use the same security settings.
SOURCE: Cannot access Appslib app library
I couldn't either! So, I uninstalled the appslib and reinstalled it and it works great now! You have to reset everything and you will lose apps I guess if you have any, I had none so this didn't affect me. If you go to Coby's website and under FAQ's it explains how to uninstall and install. Good luck!
SOURCE: Ii have the Coby 7005
Hi, I am Steve, lets help solve your issue.
I am afraid the information you have been given is completely wrong. There is not such thing as plug and play in the android world. Android was initially developed for use on embedded devices and as such had no need to recognise external devices automatically. Version 2.1 (as installed on your device) is now quite old and cannot support it. Even the new version (froyo -2.2) does not support it.
Your device does come with a built in wireless adaptor, so you don't need a USB wireless adaptor.
SOURCE: my arnova 10 G2 will not connect to wifi network do i need a micro simcard
The powerful 1GHz ARM Cortex A8 processor sits inside an extra-slim 12
mm body weighing only 540 grams meaning your ARNOVA 10 G2 is perfect to
gather around on the sofa at home or slip into a carry case for when on
the go".
Archos Arnova 10 G2
