Recently glasses started to finish foggy and
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
