Question about Braun WK200 Electronic Water Kettle Cordless Electric Kettle
SOURCE: shuts off
Does the unit shut off only before the water boils, or does it shut off and on periodically? I just fixed my friend's WK200 Braun kettle. His would shut off and on, eventually coming to a boil. During normal operation, when you press the switch, it is connected to a rod which at its other end (ie the bottom of the kettle) is able to close the circuit allowing the current to pass through the heating element. In my friend's case, the contact had become weak - I just had to slightly bend the metal pole a little bit to provide a better contact when the switch was depressed. To repair the unit, I only needed a couple of torx screwdrivers and a voltmeter to measure continuity. (note, if you bend the metal pole too much, then the circuit will always be closed even when the switch is OFF - make sure you test for an open circuit when the switch is OFF)
Posted on Feb 03, 2010
SOURCE: My Braun electric kettle won't click on. Do I
It's possible it can be fixed. Ours also no longer clicked. I took it apart and found that the flat plastic piece in the handle that activates the circuitry in the base had broken away from the rocker piece in the base. Fortunately the same flat plastic piece conveniently had a couple of holes in it in a helpful location. I looped some wire through the holes and also around the bottom rocker piece to hold the two pieces together.
I reassembled the kettle and tried it out and it now works fine! Problem fixed.
To disassemble, take the four screws out of the bottom of the kettle. (You'll need the appropriate star bits to do so.) Put those screws in a safe location... Lift off the bottom plate.
Now, the plastic for the handle is held in place by the typical notched clasps used by so many plastic appliances. You unsnap the clasps by CAREFULLY inserting a straight blade screw driver between the handle plastic and the kettle and GENTLY prying the handle plastic away from the kettle. You'll hear the internal clasps "popping" as they snap loose. You CANNOT take the handle all the way off this way. You just loosen it. Now, the top of the handle is a separate piece. Do the same for this. The top will pop completely off.
Next, GENTLY remove the lid. You can slide it a bit up and away. It's a tight fit, so you need to use a little force, but not too much.
Once you've done this, there are two metal pins that hold the main part of the handle to the kettle. They have a little ridge around the top that you can use to pry them out with your fingernail. Once those pins are removed, the handle will simply come off.
BE CAREFUL! The various parts in the handle are now loose! If you aren't careful they'll fall off and you'll have to figure out how to reassemble them.
Now, you'll notice the long flat plastic piece running down the side of the kettle. That piece was hidden behind the handle. It is SUPPOSED to be fastened to a rocker plate at the bottom. If you look at the end of the flat piece at the bottom you will likely see what I did. It had just disconnected from the rocker plate. Take some wire and wire the two pieces together using the little hole-like slots at the end of the flat piece. Just loop the wire through the hole and down around the rocker plate piece exposed inside where the handle is.
While applying this wire, it will be helpful to put a little masking tape across the various handle pieces to keep them from falling off. This is important because you'll probably be wiring the pieces together with the kettle on its side like I did, and the parts will fall off if you aren't careful. When you are done wiring things together you just remove the tape.
Once you've done this, reassemble the kettle in the reverse order you disassembled it.
You'll notice that once you've wired together the two separated pieces, pressing the switch on the top pulls up on the flat plastic piece which pulls the rocker plate which closes the circuit in the base.
Posted on Mar 02, 2011
Feb 05, 2016 | Kitchen Appliances - Others
Feb 15, 2014 | Braun Kitchen Appliances - Others
Apr 21, 2012 | Braun Food Processors
Feb 25, 2011 | Braun WK600 Cordless Electric Kettle
Nov 11, 2010 | Braun 360° Complete 8985 Electric Shaver
Mar 29, 2010 | Braun Health & Beauty
Jan 29, 2010 | Braun WK200 Cordless Electric Kettle
Mar 12, 2009 | Braun Food Processors
Aug 29, 2007 | Braun WK600 Cordless Electric Kettle
Apr 04, 2017 | Braun WK200 Electronic Water Kettle...
722 people viewed this question
