Now remove the drain hose clamps and remove the drain
pump/valve, clean the drain pump/valve, use back flushing to clear off all
dirt. Now test using power to see if this works and can be simulated. When
refitting, the hose must be tightened properly. If the pump/valve does not work
even with power then it must be replaced.
If there is intermittent power to the drain valve/pump then the program
controller unit is a suspect. Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a
spirit level- so that all water will drain to the outlet port and thereby there
is no residual water remaining. Replacing the pump on a Bosch machine, please check
this link for tips:
