The door on my freezer is not vacumn suctioning close anymore. This just happened, no changes to the freezer.
SOURCE: freezer vaccum seal not working
check the gasket and make sure that it it not pinched and letting in air whe the door closes. primaryly around where the hinges are.;
SOURCE: Freezer LFFH21F7HW upright is making to much noise
Hi, What kind of noise is it making?
Also have you tried moving the fridge slightly incase its up against a unit or sitting uneven as this can cause a noise if after this you still have the noise their isnt much you can do about it as its not worth replacing parts that are working fine.
I would move the fridge slightly or adjust the legs so its sitting even as this can cause a vibrating noise.
Let me know how you get on or if you need further assistance ok
SOURCE: my fridge door doesn't seem to close completely - No suction?
if you peel back the seal from inside out you should find some screws. losen the screws and replace the part that came out. to set the seal just heat it with a hair dryer with the door closed and hold the seal with a putty knife until it cools
SOURCE: Frigidaire 17 CF upright freezer. We are getting
It could be the button that the door hits on when you close the door. If you can take it out and clean the connections it may do the trick. If it really bugs you then you can twist the two wires to gether and it should fix the warning. This means the button switch may have went bad but if you know the door is closed who needs the annoying warning. Please leave a thumbs up. I can only try for you from way out here in the Raz Shack
SOURCE: WHY CAN'T I HERE THE VACUUM SOUND ANYMORE WHEN THE FREEZER DOOR SHUTS?
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
