Question about Jackson 25 in. TempStar HH Free-standing Dishwasher
From 300w psu i change it to 450w will that be ok?
It really took me a long time to solve my problem bout my computer, and here it is i found a nice site to share my problem hope you guys can help me solve my problem. im always experiencing a problem regarding with my power supply everytime i purchase a new power supply it will work only less than 6 months. one of my friend suggested me that i will replace may atx 300w power supply to atx 450w and she explained me the reason why i should replace it,so i think she got a point and the other reason is atx 300w power supply is almost face out, so i follow her advice and buy a atx 450w power supply.when i tried to turn on my computer using a atx 450w power supply it does not work but the LED in the motherboard lights, but the fan from the process is not working, no beep sounds from the board, i try many times to check all the connections and i think i connect them in proper. i have a p4s133 asus motherboard. Is anyone familiars the connections of a p4s133 asus motherboard? because im a little bit confuse with the connection beside the motherboard supply the AUX ports i think, should i put a supply on that? what should i check first to solve my problem? and replacing a atx 300w power supply to 450w power supply will that be ok? should i separate the power outlet of my monitor? because my monitor is connecting to my cpu. your reply is really a big help for to solve my problem... thank you!!! ivy
  • ivy condrad Jul 16, 2007
    hi dog,
    i dont know your name, will that be ok if i call you dog?thank you so much for giving time and posted me a suggestion to solve my problem, but still my problem in my computer didn't work i try it many times i connect and disconnect all the connections but still my computer didn't work. is there any other suggetion to solve my problem? please help me.....
    ivy
    hi dog,
    ivy
    Novelist:
  • 159 Answers
Ivy My field is in home appliances. I do fix my own computers and have replaced a few power supplys. The only thing I could say to you is go back and recheck your connections. They should only fit on the bord one way. The other connections for the hard drive and cd drives and so on really dont matter. so good luck and I think if you recheck it all the computer will work.
Posted on Jul 12, 2007
6ya staff
SOURCE:
I have a 518 inspiron by dell with a 300w PSU can I put 550watts
Yeah, you can. This would only be a problem if you had a really old desktop
Feb 10, 2013 | Dell Inspiron 518 Desktop Computer
Dell Inspiron 530 - Plug it in, immediately powers up, PS fan and Video card fan start, power button shows amber light and does not turn off power, motherboard shows amber light instead of green;...
Hi
This seems like a power management problem on the motherboard.
Disconnect the power cable. Remove the small silver CMOS battery for 2 minutes to clear the BIOS Memory. Reinstall the battery and reconnect the power.
Look carefully at the power lines coming from the Power Supply Unit (PSU) and make sure that no one power channel is powering an unequal load of devices. Try and divide the load as evenly as possible amonst the power lines.
If none of this solves the problem, then consider upgrading the fitted 300W PSU to one with a higher Wattage, as 300W is on the low side for current standards. 450W-500W is more typical nowadays. The higher the Wattage you can afford (up to a 650W maximum for this particular specification of PC) the better
A higher wattage PSU will work well within its capacity and therefore under less strain than the current one. The symptoms you describe could be signs of the current PSU straining at the limits of its performance range to power all the devices inside as well as maintaining the computer's heavy workload of interaction with all the devices connected to it.
I hope this helps.
Aug 26, 2011 | Dell Inspiron 530 Desktop Computer
Just got a Asus m4n68tm motherboard 250 processor 2gig ram to go with a half gig hd and a 450w psu. Assembled everything nicely and fired the thing up only to find - no video. Everything seems ok but...
try removing you ram and putting it back in make sure it locks in place, and make sure your cpu installed correctly and securely. Also try clearing the bios. If this does not work reply back to this posting with you complete configuration make and model of every thing.
Feb 11, 2011 | ASUS M4N68TM Motherboard
I bought an Ultra LSP 650w power supply (upgrade) for my HP a1150y and it won't even boot up (fans come on & thats it). If I put the old 300w (oem) PSU in the PC, it works but it won't meet the power...
if thats wat the specs say then thats most probably the max youve just bought one thats to powerfull, and y did you need so much power the most powerfull graphics card in the world needs a 750watt power surpply, your computer is probably not designed to have major upgrades, and by looking at the specs i can see that your computer well putting it simply is **** for upgrading the specs are **** (no offense intended) i suggest upgrading to a whole new computer if you want that sought of power and graphics
Feb 17, 2010 | XFX NVIDIA GeForce 8500 GT 256MB DDR2 PCI...
New build pc no boot... black screen
Try to remove the battery from the MB, and next time you try to install WIN XP, when you are asked how to format your drive, chose quick NTFS formatting; disable floppy drive in BIOS, because it might try to boot from it (and I suppose you don't have one), and in boot sequence (BOOT DEVICE PRIORITY) set cd-dvd as first, and HDD as second, and turn off any other device as bootable
Nov 17, 2009 | ASUS M2N-MX Motherboard
Dont't boot anymore since my power supply died
When the power supply failed, it took the motherboard out at the same time. Time to replace it.
Oct 17, 2009 | ASUS P5GD1 Motherboard
I have a gateway 506gr with a Bestec atx300 psu. I was having problems being able to turn the computer on, then one day it would not turn on at all. I can push and hold the power button, and hear the psu...
Your psu is works fine.
First open cpu cabinet and find motherbord.
Pull CMOS cell from m/b for 10 minutes.
Refix RAM Memory.
Pull procesor fan and processor clean dust from all parts.
Then fix processor fan and processor.
Reconnect ATX connector to m/b.
Remove pci cards from PCI slot then check.
Let me know if you need more assistance.
Thanks.
Oct 01, 2009 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Installing graphics card
Well you open the side cover and then you remove the old video card and then you install the new video card mke sure it is seated in the slot really good and put the screw back in repower up your computer a screen will come up say something like windows has found new hardware cancel that out by clicking on cancel then put your cd in with the software for the new video card and follow the instructions one it and you should be set when the computer reboots up
Jan 03, 2009 | Computers & Internet
Its not really a problem but i need to know how much watts my power supply has.
this VGA card requires about 250w under load. the HP PSU is unlikely to have enough power. get a good quality 450W or better unit
Jul 25, 2008 | HP PAVILION A6230N DESKTOP PC
Jackson 25 in. TempStar HH Free-standing Dishwasher Logo
1,999 people viewed this question
Top Jackson Dishwashers Experts
Marvin
Marvin
Kimberly Opager
Kimberly Opager
Level 1 Expert
handygirl911
handygirl911
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
