Casio FX-9860GII Graphing Calculator With USB Cable Logo
Posted on Jan 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to use square root for non square numbers for casio graphing calculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Casio Master 102,366 Answers
  • Posted on Jan 17, 2013
Casio Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10443258
Points
622693
You can use the square-root function for any number, whether it's a perfect square or not. For example, to calculate the square root of 2, press SHIFT [square-root] 2 EXE .
[square-root] is on the x^2 key, just to the right of the ALPHA key.
1helpful
How do I get all the factors of a constant using my calculator?
There is a program on page 253 of the manual (http://support.casio.com/manualfile.php?rgn=5&cid=004002013) to get the prime factors of any number. You could modify the program to get all the factors.
Another way would be to do it manually. I start with the number 1 and go up to the square root of the number. The square root of 120 is 10.95, so let's go up to 11. Using 120 as an example:
120 /1 = 120 thus factor is (1, 120)
120/2 = 60 thus factor is (2, 60)
120/3 = 40 thus factor is (3, 40)
120/4 = 30 thus factor is (4, 30)
120/5 = 24 thus factor is (5, 24)
120/6 = 20 thus factor is (6, 20)
120/7 = 1.7 thus 7 not a factor
120/8 = 15 thus factor is (8,15)
120/9 = 13.3 thus 9 is not a factor
120/10 = 12 thus factor is (10,12)
120/11 = 10.9 thus 11 is not a factor.
Good luck.
Paul
How do i find the square root of a number on the casio scientific calculator
If, for example, you're getting the square root of 3 as the square root of 3, press the S-D button (just above the DEL) button to convert the symbolic result to a decimal result.
If you want all results to come up in decimal, press SHIFT SETUP 2 to select the LineIO mode.
How do i find square root in casio fx 350 ms
Use the square-root key (three keys up from the "8" key). For example, to calculate the square root of 2, press square-root 2 =
Need instruction how to solve ploynomials/trinomials
You can do it two ways.
Graphically:
Open the graph utility, enter a function y1= expression(x) where expression(x) is the polynomial. Graph the function y1(x). Play with the window dimensions to display the interesting part of the graph. You can then see if there are any zeros (roots).
While the graph is displayed, press SHIFT F5 (G-Solv). Press F1:Root to look for a root. Read the value of the root at the bottom of the screen (to the left).
Solve utility
Open the QEquation solver, select F2:polynomial, or F3: solver.
The polynomial solve can solve polynomial equations up to degree 6.
The solve solve polynomial and any other type of non algebraic equations
I dont know how to find the square root on my casio fx-300ES scientific calculator problem it wont let me square root 42 , when i square root 42 , 42 keeps coming and not the answer
To calculate a square root you press the square root key. A radical will be displayed. You type in the positive number whose root you want. Press the EXE key.
Square root function
You can find square root by giving your desired number ^ 1/2
1helpful
How can I get the square root of a number that a simple calculator can get?
To calculate the square root.
Press the square root key, enter a positive number, close the right parenthesis (may be omitted) and press [=].
1helpful
2answers
How can i graph x cube-9 on my calculator
For example if you are doing the cube root of 8 (answer is 2)
Type 3
hit shift
Press x of square root key
type 8
Press ans key
1helpful
2answers
Need to know how to do squre roots step-by-step
type 2nd then the square root sign and type in the number u need. the close off the parenthesis and hit enter
Top Casio Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
