THE MAGNET WILL TURN ON BUT WHEN I PUSH FORWARD OR REVERSE THE MAGNET LIGHT JUST BLINKS AND THE DRILL HAS TO BE TURNED OFF AND BACK ON AGAIN TO RESET THE BLINKING LIGHT.
Sometimes you face a lot of problems with the motor. If you are looking for a portable drilling press that is strong at the same time, you should give Evolution Power Tools EVO28 Magnetic Drilling System a try. It is easy to maneuver and the strong motor can dig deeper holes pretty fast. More details Best Magnetic Drill Presses for Smaller Drilling Tasks
Magnetic drills have a safety system built into them so the motor will not run unless the magnet is on and the tool is sitting on between at least 1/8-inch and 1/4-inch steel. If your drill is sitting on enough steel you may have a problem with the sensor system inside the drill. Those problems are usually electronic parts related and, most of the time, they are R&R (Remove & Replace) method is used until you fix the problem.
