The service manual (with exploded views, disassembly info, and part numbers)
is
here.
You can order GE parts from the Pros here,
our favorite supplier.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of
our answer.
SOURCE: GE Advantium 120 Speedcook Oven
THERE IS NO EXTERNAL VENT NO NEED TO CUT ANY HOLES GO TO THERE WEB SITE AND YOU WILL FIND THE MODEL YOU WANT, THERE ARE SEVERAL--IF IT IS VENTED IT HAS TO BE IN THE UNIT NO OUTSIDE VENT, IT IS A HOLEGEN LIGHT BULD WITH A MICROWAVE
SOURCE: replace fuse on GE Advantium Speedcooker Oven
there is a fuse located underneath the outer cover, its called a ceramic fuse and is of cartridge type about 1" long by 1/8" diameter and has a white body and 2 silver ends and you can take it to a hardware store they have them but make sure to get correct amperage rating 15 or 20 amp
SOURCE: Need to replace fuse in GE Profile advantium oven
remove outer shell/cover, the fuse will be in a fuse holder about 1" long X 1/8" in diameter and is called a ceramic fuse,take it out,look on ends for current rating go to hardware store they have repl fuses, if the new fuse blows it could be your h.v. diode, capacitor, or the magnetron tube
