I search the web but no solution found warning lights are all 3 on
Ok, check the brake fluid level for a start. This could mean a few things. Your brake pads might be worn down, which would bring a yellow warning light on(triangle), at the same time with the pads being low it will have displaced the fluid, making the level low, this would be a red light on. Now because of this the body control module has detected these faults, will have turned the abs off, hence the abs light.
If brake fluid is low, this could confirm my theory.
If its low, top up with dot 5 brake fluid and take to garage to have new pads fitted.
TL
The triangle is traction control not brake lining. Also the abs light will not come on for brake fluid issue. More than likely, you need a wheel speed sensor
Are yellow ABS Red brake and yellow triangle I think is anti slip
I have the same problem on my 2005 mini cooper s, and i check all the fluid and the brake pads and everything is ok.
Which lights are on exactly/ Are they red or yellow?
brake light and abs light wont turn off
