Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
len gardner Posted on Jan 15, 2013
Epson Stylus SX115 not starting
When switched on the copier head tries to drive head passed the home position This continues with the drive chattering (slow machine gun) until it ties out and switches of and it is left with the ink and paper lights flashing Can anybody help
phillip
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Jan 15, 2013
phillip
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
Helped
13322
Points
25
Need more information try to expand on what is wrong.
5 Related Answers
Anonymous
  • Posted on May 27, 2008
SOURCE: Epson stylus photo R1800 printer
http://www.fixyourownprinter.com/forums/printer/35608
this website will answer all your problems
aicaxz
Anjazmoro Wicaksono
  • 511 Answers
  • Posted on Jun 26, 2009
SOURCE: alternate flashing red lights on epson stylus photo 900
Flashing alternately? Need reset waste ink. SSc ver 4.3 support this model. Find at indoreset.blogspot.com.
Anonymous
  • Posted on Feb 16, 2009
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
Anonymous
  • 677 Answers
  • Posted on Mar 27, 2010
SOURCE: How can I remove from my stylus sx115 the ink
Found this on the web. You can download the entire
manual if you like. If you find this helpful, pls rate me.
ftp://download.epson-europe.com/pub/download/3233/epson323393eu.pdf
Anonymous
  • 50 Answers
  • Posted on Dec 08, 2010
SOURCE: HOW TO GET THE INK
Please check this link http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=emW65r3CP2GmdoIiALwQx9OKn7AxVBUo&tc=5
How do I align print head Epson sx115
Hi there
The easiest way is from the Maintenance tab of the monitoring software that comes with the printer. I don't know of any way to align heads from the buttons.
If you right click on the printer icon on the task bar, then a menu will come up and you can then click on the "Head alignment " and work from there. Alternatively bring up the "Devices and Printers" in Control Panel and under Printer Management click on "Adjust print options and then the maintenance tab on the window that comes up.
If you need more information, you can a user manual as a zip file and then HTML format here:
Epson Stylus SX115
Hope this is helpful, if so would you please register that with Fixya
Cheers
12helpful
2answers
Paper Feed on EPSON STYLUS SX115
go reclaim to the epson service agent or where you purchase.
Note: take all ink cardriges out. they dont need them.
Epson stylus cx3200 printer when switched on display says printer error get assistance fron engineer
Check there is no foreign objects in the way of the print head. Check the encoder strip is clean and in tact. Ensure the print head can both leave and return to the home position easily. Check that the head lock is retracting when power is turned on.
1helpful
2answers
Epson stylus photo R 230 series
unless the head come to a halt during initialization process, upon turning on your printer there is no way you will be able to print, please check for any obstruction on the printer head, the grinding sound is an indicator that the head is trying to reach its position and was having trouble. or it could be a damaged belt that you need to replaced
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
