Cars & Trucks Logo
Posted on Jan 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi.. i have a 2004 range rover and on the message center it tell me that the air suspension is inactive, hdc is inactive as well as selflevel air suspension is inactive... is there any way i can troubleshoot this problem?
  • asif_rana Feb 07, 2009
    Hi, iv got the same prob, dash displays suspension is inactive do not exceed 35mph. i can drive over 35mph but the little orange lights on the hight control switch do not work???? and does not show what hight the vehicle is sitting at. Is this a electric prob or a prob with the air pumps????
Jeffrey Babiuk
Level 2:
Scholar:
  • Land Rover Expert 129 Answers
  • Posted on Apr 17, 2009
Jeffrey Babiuk
Land Rover Expert
Level 2:
Scholar:
Answers
129
Questions
Helped
86150
Points
250
The EAS can have many different faults that will give the same warning. I have had several air susp problems. First try to disconnect the battery, wait several minutes reconnect then drive car making at least on full circle. If lights remain, air pump (under spare tire ) can be checked, also valve under a cover behind right front wheel, other than these areas, the Testbook diagnostic at dealer will determine if any other parts are source of problem. Unfortunately, with the complexity of the system many other parts Height sensors, etc, etc can also cause the error message. Good Luck.
2answers
2004 land rover range rover hse transmission is overheating and drives like it's in sand or mud. Also have air suspension inactive warnings along wIth HDC inactive suspension light dosent even lightup
check that you are not in 4 x 4 settings on hard surface as that loads up the transmission making it work harder
that it turn can over heat the transmission oil
check for correct oil level in transmission as too much oil or not enough will also heat oil
take it to an accredited service center that has experience on your make of vehicle for a diagnosis of all problems
1helpful
2answers
Hdc inactive range rover
In respect of the display message 'HDC inactive'. I have and still do occasionally get the same message. I took the vehicle to a Land Rover dealer and was informed it was a common problem particularly when the vehicle is started from cold and more so during cold weather. The dealers have it registered as a bulletin repair and are able to provide a remedial fix, however it's a case of the display message being present when you take it to the dealer!!!!!
1helpful
My 2003 range rover is reading air suspension inactive and it will not go
Try using a scanner to read codes or re-activate, also have a look at the air suspensions bag/balloons, might have a leaky one. If so change, check air suspensions activator unit too. Valves may ber bad.
2helpful
Am receiving a message on my Range Rover 2004 Inactive suspension
Welcome to Fixya
Air suspension is currently in fault mode. It will have to be re-set by someone who has the Land Rover scantool (either a dealer or an independent shop). The EAS system is inaccessible with a regular OBDII scantool. The car will not allow you to control the suspension height (raise/lower/defeat) until the fault is cleared. Please see this link .
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
2helpful
HDC Inactive message
hi today i was driving my land rover 04 plate parked up at a shop and when i got back in to start it the engine took a while to fire up i then drove it home and turned it off when i got there now it wont start although the engine has enough battery power to turn the engine as normal it wont start at all it just turns and turns the engine over and now have hdc inactive message on dash ....any ideas pls
2answers
My 2004 range rover's battery died. Once I put on
take it to the dealer have them run a code search on your car it will tell all
2helpful
What does hdc inactive air suspension inactive trans safe failure mean car will not stay started
This error could be casued by a poor battery - particularly in cold weather. If you suspect your battery may be in poor condition, try recharging it over night.
The error can also be caused by a worn suspension compressor.
You could visit a Land Rover dealership or if you wish to save yourself the heavy costs you could visit an independent workshop who can check your car's memory log which may provide further information regarding the fault.
Check www.rangerovers.net for further information.
2004 Range rover front right suspension air leak
good chance broken line going to that cylinder. it is still pushing air but just not making it all the way there look at the bleeder valve or the fill valve get spray bottle with soapy water spray suspension in the area of the valve look for bubbles.
Air suspension "inactive" message appeared.
check owner manualis ha a swich i can remember togod but some of them work by it self when you put the gear working. star the car open the hood close to the front yopu have to hear like a little compresor that means this device is working. you remember someone jack it up the truck and forgot to shut of the swich????
104helpful
15answers
Air suspension inactive, HDC inactive, ABS light on, Range Rover
Air Suspension Inactive usually means there is a problem with the Air Suspension. However, it will also come up when alternator or battery voltage is low, or when you reset (disconnect and then connect) the battery. To reset it manually: while in P(ark), turn steering wheel all the way left, hold few seconds, and then all the way right, hold few seconds. All the warning lights will go out. Most common failure is the passenger front air strut, since batteries are prone to leaking acid, it leaks right on top of the rubber airbag and burns through it. Dealer willcharge you one hour to diagnose, or you can easily diagnose this by looking at the ride height of each particular corner of the truck. If its sits low, or emits hissing sound when you park the truck, its leaking. If you keep driving with leaky air strut, you risk burning up the air compressor, as its working extra hard to compensate for the leak. Replacing the strut is easy 45min job even for a novice mechanic, and you can do it yourself. Strut can be found new for approx $750 online. If you are fed up with air suspension issues, there is a $700 kit that converts the truck to springs, and disables all of the air suspension. Look up Arnott Industires
Top Land Rover Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Land Rover Expert? Answer questions, earn points and help others
