I've been using my MiFi XM2go for year without a problem. In the past week or so I've been getting just static or no sound at all with an occasional glimpse at the station on the XM. The bars on the screen show its got the signal and the information about the song/show is right there, so I know the signal is coming in. I was told by XM that I should get the Sure Connect or an XM FM Modulator Relay, but wouldn't this only be a problem with the FM Transmition. I've used the plug for the tape deck and have the same problem. I know its only $20, but I'd rather put that towards a new unit if I know this wont fix the problem.
I agree with you. It sounds like an internal audio circuit problem, especially if the tape adapter does the same thing. Have you tries headphones on the unit? If they work, then get the sure connect as it plugs into the headphone jack (Aux out jack)
By the way, you as an XM customer for years, usually XM will just give you another unit to keep you as a customer. I've seen it many times. Couldn't hurt to ask!
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
