120V 60HZ 155W E234498 SERIAL # j29823867 model #blc320em9 manuf 7-08j
SOURCE: CODE FOR A REMOTE CONTROL
I am not sure of the model remote but, on the newer TW remotes you would press tv then press and hold set up until the tv light blinks twice. then enter 991 on the number pad and then press power once. then press the channel up button until the tv turns off. as soon as it turns off - press the power button and if it turns on then you have the right code. If it doesn't turn on then press channel down until it turns on. either way, when the tv turns on then press set up again to lock that code in. Hope that helps.
SOURCE: have a emerson blc320em9 a,
You will need to replace your high voltage transformer or flyback. You can get a replacement at http://tigerdirect.partsearch.com
SOURCE: I have an Emerson LCD
Tries tv unplug,replug it back like about an hour later.The tv now it resetting itself back to factory setting should work again.If have the same problems,the tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
It is my pleasure to guide you.
