I have a casio ex-z600 camera. It was working fine until a few days ago. Now I can only take three pictures befor it says that my memory is full. I could take many pictures before without any probs.
My camera isn't reading the memory card. I have tried reformatting and resetting the camera but this still doesn't work. I am using a memory card I have successfully used before, even after swapping this over all the images are just on the camera and not on the card. Help!My camera isn't reading the memory card. I have tried reformatting and resetting the camera but this still doesn't work. I am using a memory card I have successfully used before, even after swapping this over all the images are just on the camera and not on the card. Help!
You can't post conmments that contain an email address.
First off did you format ur memory card? Casio only has 3 brands of memory cards they have tested their cameras with....Sandisc, Toshiba, and Panasonic. The exz600 can take up to a 2 GB card from those manufacturers with no problem.
I would make sure that your mem card is formatted. If it is, try a different card.
If you don't care about the pics that are stored on your internal mem then you can format your camera, put in a new mem card and then format that.
You always have the option of transfering the pics to ur computer first before formatting.
After formatting make sure you reset your camera also.
Format:
in REC mode press menu
go to setup tab
go up to format
press right arrow
make sure format highlighted and press set
Camera will say "busy please wait"
Reset:
In REC mode press menu
go to setup tab
go up to reset
press right arrow
make sure reset is highlighted & press set.
I would recomend you to reset the camera, this will not affect any of your saved pictures.
This can be done simpely by acessing : Menu, settings, reset to facory settings (Factory settings)
I have a casio exilim 8.1mp ex-z80 green digital camera. The casing is no longer presentable. Do you know where is the CASIO SERVICE CENTER here in the philippines, specially in davao city...
I've checked google for a few solutions, and it looks like CMOS chip (optical chip that takes picture) could have a problem (not sure though, but it seems the most obvious solution). You should take it to the store You bought it in, and ask for a replacement or repair
The problem is the spring terminals inside the camera are not making good contact with the battery. I had to use a screw driver and gently push them to the left to make better contact with the battery terminals. There are three connections. I stress that you be gentle. This not the long term fix but you will be able to take pictures in the short term.
Hiya yeah i had the same problem i only found out a few days ago and i had it since the summer hahaha.. emm well mines a cassio ex but im not sure about z600 but what i do is.. while im taking the pic.. click menu.. and lots of options come up ya just have to keep scrollin across >> and then der'll be an option (sori i cant remember wat it says because mi cam is after breakin on me) and de options to the option (sori sounds complicated) are .. 0 seconds.. 10 seconds.. off.. 20 seconds.. that kinda thing..click one'a them that shud do it..
