77 shovelhead w joe hunt mag and s&s oil pump everything is great except after about 20 mins of riding oil start coming out of gasket all around cam cover and mag assembly dont know what would cause...
There ae a number of things it could be. What it sounds like to me is that the oil is not being pumped back into the oil tank and is collecting in the cam chest. It should be blowing out of your crankcase breather tube as well if your crankcase breather tube is open. Behind the oil pump, there are three holes. One is behind and above the oil pump. This is where the breather tube from your oil tank and the primary comes into the engine. The hole directly behind the oil pump in the middle is the oil return line from the very back end of the primary where the oil from the primary is recirculated back into the engine. The bottom hole behind the oil pump is the crankcase breather. It should have a hose that runs back around behind the transmission and just dead ends in a bracket pointed towards the final drive chain. This hose should be open to vent the crankcase pressure. Have you checked to see if oil is being pumped back into the oil tank? If not, the scavenge gears of the oil pump may not be pumping the oil out of the engine and back to the tank. If this is the problem, you may not have the drive key properly installed in the scavenge gears of the oil pump. Still, oil should be pouring out of the crankcase breather hole. But, this is what it sounds like it's doing to me. The oil is building up in the cam chest for some reason.
Good Luck
steve
