I just bought a new battery for nokia 6630 and when i connect it to the charger it's not charging while the old battery is still can charge so any sol??
yes once check ur charger and all pins of that charger and check the phone pin at connnet of the charger if it not works u should change ur chrger or phone pins ok thinks and all the best and please OR: Please change Phone In The CHARGING JUMPUR rate my answers too
I had the same problem. Put the battery in an old Nokia desk charger (the docking type), aligned the contacts as the battery is smaller than the housing and left it overnight.
Hi Friends, I am Raheel Ansari from Pakistan, Karachi. My 6630 's battery is getting discharged very soon I have buy New Batteries but issue still remain. kindly help me out in this regard.
TRY TO CHARGE UR PHONE BY SWITCH OFF IT IF ITS NUTS SOLVE THE PROBLEM THAN DONT GO FOR ANY OTHER CHARGER AND HIGH VOLTAGE IT CAN DAMAGE TO UR PHONE SHOW UR MOBILE ANY NEAR MOBILE REPAIRING SHOP
HI
THIS IS DUE TO YOUR MOBIL DOES NOT GET THE POWER FORM THE BATTERY
= pla check is the battery is connected properly
== in order to check if there is problem in battery you can unplug the battery and connect any other battery
== if the phone is on then the problem is in the battery other wise i m afraid the problem is in the phone
GOOD LUCK
