How to resolve that problem mentioned above. It's driving me bananas. Thank you.
SOURCE: 580ex not flashing at all
after using it many flashes at 1/1 power the strobe doesn't work anymore
SOURCE: 580EX speedlite not firing
Does the pilot lamp light up? If so can you fire it manually by pressing on it? If the batteries are low it may simply just be taking a while to charge, the camera will not wait for it to be ready to fire and it may seem to be not working. If your flash can be fired manually however, there may be a problem with the cameras shutter or the hotshoe. You can do a basic check by pressing the star button at the rear of the camera, you should get a pre-flash. If not, there is a problem with the cameras hotshoe which you will need addressed by a service centre. If you get a preflash you can next check the cameras shutter by setting the second curtain to sync with the flash. This can be done via the cameras "Custom Function" menu, c-Fn 15. Set the camera to TV mode and chose a 1 second exposure. Take a shot with the flash attached, if the shutter is working correctly, the flash should fire a pre-flash and then a main flash. If it doesnt, the switch inside the shutter is broken and the shutter needs to be replaced. This is a pretty labour intensive repair and you may consider an upgrade as more economical.
SOURCE: Canon speed lite 580ex 11
I just got the 580 and had trouble with it blinking all the time, the bounce card was out about a mm and I did not realize it, once that was pushed all the way back--voila.
SOURCE: Canon speedlight 430EX II won't fire
The conceting piece of the Flash has cracked when i dropped it, is there any thing i can do to repair or exchange it?
SOURCE: Canon 430EX II flash... batteries A-OK. But flash
Hello
Thank you for using FixYa for your problem
Sounds like the flash tube has gone.
It should be taken to an authorized repair centre for a repair estimate.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
