Hi Sherry,
The code definition for LF is a LONG Fill (F30). What does that mean is the next question? Here goes.
a. The fill hose may have a pinch or fold between the connections on the pressure in .
b. Are the hose screens plugged at the connections.
c. Is the water siphoning out of the drain hose ?
d. Is the water pressure at peak, check valve, filters before washer.
Now if your savvy hungry. Here is a learning curve link
Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis .
Okay. The next link is for the manual for your favorite machine.
Manuals and Troubleshooting Whirlpool Whirlpool Cabrio Washer Fault Codes . I tried this and you need registration.
I decided to go one step further and track down a printable and savable resource for you. Yes, all, the fault codes and what they mean.
I did pretty good from memory but that link leads you to a printout you can keep right by your washer. Most of the occurrences are easy to fix without a technician. Hope this makes your day. Better. Fare. Well.
