Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU Logo
A
Anonymous Posted on Jan 13, 2013
Reading the wrong temperature - Sta Rite Sta-Rite Max-E-Therm High Effiency - Propane Heater - 333,000 BTU
I have a frigidare range and it is flashing F10 and Beeping repeatedly
The "F10" error code caused by the runaway temperature.
The first thing I would check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It suppose to be about 1100 Ohms at the room temperature.
If the resistance at the EOC plug is wrong, then measure the oven temperature probe resistance at the probe plug.
If it's wrong - replace the oven temperature probe. It's better to hardwire it, using a high temperature ceramic wire nuts.
If the readings at the EOC and at the oven temperature probe plug are different - check the wire harness between the oven temperature probe and the EOC.
If there is nothing wrong with the oven temperature probe resistance - replace the EOC.
Here is the probe to order.
Here is the EOC to order.
1helpful
2answers
2002 Ford explorer outside temperature reading is wrong. Changed temperature sensor between grill and radiator but still wrong temperature reading on dash. Reads 10 degrees too low all the time and it does...
This may be a wiring issue as the sensor is electronic in nature. Any loose wiring may cause the voltage across the sensor to differ resulting in an inaccurate reading.
2helpful
2answers
F10 oven code frequently beeps,often after cooking is over and oven is coolind down at different temperature settings tempermental some times it works sometimes it does not.
Frigidaire FEF352BADB electric range gives an F3 error code when oven is turned on. The oven temperature sensor apparently is good as it reads about 1050 ohms. What else can I check and how?
F3 - Open oven temperature sensor (RTD)
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
It suppose to be about 1100 Ohms at the room temperature. If the reading there is wrong, check the sensor resistance at the sensor plug and the wire harness. If there is nothing wrong then replace the control board.
Hope helps.
2helpful
Was cleaning oven and error code F10 appeared what is a error code F10?
hello there"
- The part number for the oven temperature probe is AP3704441
- The part number for the EOC is AP3776874
- The part number for the EOC overlay is AP3778486
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/4431-f10-error-code.html#ixzz156CO7RjB
Having issues with my temperature gauge. Replaced the thermostat, coolant temperature sensor, and we're still having issues. Thinking it may be temperature gauge sensor, but we replaced it with an older...
has to be either a sensor or a gauge ,reading the wrong resistance ,try taking some old resistors out of an old tv and putting them in line and seeing then if you get it to read right
Error code F 10 during broiling. model #790.78649601
The first thing to check is the resistance across the oven temperature probe (aka oven temperature sensor) terminals at the EOC (electronic oven control) plug.
2helpful
2answers
Aqualink RS4 Water temperature reads 120 - obviously wrong.
No but this sensor is easy to replace. Just pull the sensor from the pipe by loosening the staniless steel clamp that holds it in the pipe. Then follow the wire back into the Aqualink box and unplug. Get a new one at your local store and replace. It's a common problem and you should be able to do it with ease.
F 10 code when I try using oven
The first thing I would check is the resistance across the oven temperature probe (oven temperature sensor) terminals at the EOC (electronic oven control) plug.
It will be about 1100 Ohms at the room temperature.
Please rate and have a great day:)
Out side temperature reading
Without having parts to try, this would be difficult to know what the fault is. Inside this unit there is a circuit board, and on the outside there is the exernal temperature sensor.
There are only a few things that can go wrong. There is not much that is servicable unless you can find a spare board, or a spare temperture probe. There is very little posiblity that in any practicality this unit can be serviced at the component level.
I would just go out and buy a new unit.
Jerry G.
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
Sean Wright
Sean Wright
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
