Are you sure the derailer or sprocket are not bent? The next thing if not that is the cable itself is it pulling the delairer to release the gear from the gear it is in? one final is the bike just may not go into 6th gear depending on which gear you have the front sprocket in because it would pull the front sprocket to far past the crank space where the pedals are at.
the derailleur cable is too loose. Shift the shifter into the smallest cog, make sure the chain is on the smallest cog. The derailleur cable will most likely be very slack now. At the rear derailleur, there will be a nut or a allen bolt pinching the cable to the derailleur. loosen this, pull the cable finger tight, tighten the nut or bolt again and then try shifting again. You can dial it in using the barrel adjuster on the derailleur or the shifter.
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
A reputable Bicycle Shop would have fit the bike to you before you took it home.
The chain goes from the top of the front sprocket to the top of the rear sprockets, between the rear sprocket and the top derailleur wheel and then between the upper and lower derailleur wheels. It then goes forward toward the front sprocket. The text sketch below shows the rear sprocket, chain and derailleur.I hope this helps.
You will need a 6mm allen key to loosen ( turn anti clock wise) the handlebar stem bolt which when you sit on the bike and look down its just under yer nose :)
Please make sure when you raise the handlebars that as it lifts up there is a marking on the side of the handle bar "stem" with markings like this """"" if you see these you need to lower it down so you cannot see these.
