I see you are an expert here. Hope you can advise me some. My washer fills up fine but when it gets full it starts draining and the water keeps trying to fill it but it all drains out and the water continues to run until we manually shut it off. I would say this happens about 65 percent of the time. It also does the when it gets to the rinse cycle. The water will just keep running and not fill up and it just sits on rinse until we manually move it to spin.
Any suggestions?
Yes im a expert (laugh)...your drain hose is to low..the drain hose must go up the height of the unit abut 3 feet before it can go down...now if you have your drain hose connect directly to your drain pipe ,,the waste pipe will **** the in coming water right out of unit,,we call this a sphion effect...booth easy fixs,,,onthejob
