SOURCE: needle picks up bobbin thread but then thread gets stuck
I've had similar problems (as well as other problem with the thread breaking all the time and the "shuttle race" thing that holds the bobbin falling out. One very important thing that isn't mentioned in the manual but that the salesman stressed is that you have to use only "Schmetz" brand needles. They are a tiny bit longer, but that makes all the difference in the world if your stitches are skipping. I forgot and used Singer needles and had horrible results.
SOURCE: Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
SOURCE: Model 3205 FA not picking up bobbin thread, needle
- check ifu are using same needle model.
- check hight of needle bar is ok
- check timming between needle bar and hook.
- check if your material is very stritch or no
- check blad point of hook is ok or no
best regards
SOURCE: top thread will not pick up the bobbin thread
Timing is off, is is possible that you broke a needle or sewed over a pin. timing needs to be re set by a professional.
SOURCE: sewline 20 timeing problem. I broke a needle and
If you email me I can attach timing instructions [email protected]
