Hi, Was wondering about how one goes about synchronizing the two time formats on the T-touch. I've recently had the battery changed and they didn't adjust that, and I don't have the manual on me either. Any suggestions? Is it possible to adjust the compas needles as well? They're no longer aligned in the straight line like they used to be. Thanks, Shahzad
Push the middle button then touch the centre screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds."Synchro" will appear on the display. By using pushers + and -, bring the two hands pre-cisely to 12 o'clock Incrementation of the minute hand(3 steps=1 minute) Incrementattion of the hour hand(3 steps=1 minute) Press the middle button to validate the setting.
Thax
Push the middle button then touch the center screen selecting the "nits" mode(24 C m), then push the middle button again for 5 seconds. "Synchro" will appear on the display. Using pushers + and -, bring the two hands pre-cisely to 12 o'clock (do not hold down both buttons at the same time, just use each + and - button independently until both hands reach the 12 o'clock time). Then press middle button to validate the setting.
After validating setting, go back to home screen and hold down the + or - buttons until you reach the current time.
I added this review since I was having trouble even after reading some other posts...good luck!
Tissot Touch Expert Battery Replacement calibration Watchmaker Video...
In my blog you can see in the third video how can you synchro the hands and how can you reset the watch.
Gracias, pude sincrinizar mi reloj con el consejo.
Alejandro Barrera
These things are adjusted at the time of cell replacement. take the watch to someone who knows how to do this properly.Check there web site to find a dealer http://www.tissot.ch/
Solution by nikarif works! Thanks a lot!
I cannot get any of the functions to work. The box does not include the operating manuel. I had the battery changed and that caused the time needels to read different than the digital time readings. Do you know where to get an operating manuel???
[email protected]
The needles and digital read are showing different times. Can't synchronize them?
"Solution by nikarif works! Thanks a lot!"
ditto for me. I didn't think I'd find a solution that I could do online, but am VERY happy to have. Thanks again!
-Stephen
I have had my watch for almost three years now. Suddenly it turned off and I thought the battery was dead. However, the watch turned back on just as abruptly but now the digital time display and analogue (minute and hour hands) are out of sync with each other. I can set the digital time, and it reports it accurately, but when I do so the hour and minute hands do not set to the same time.
I also have the same problem, arms are not in good sych.
hands not syncro with digital display
that helped a lot i have been too busy to be able to change it but it started to bug me
I have exactly the same problem. I stopped using the watch for a while (purchased a new watch!) and decided to go back to this one for a 'change', but hands are out of sync
How was it solved?
Again, manual mislaid so can't remember how to do it.
Thanks
ditto for me. Many thanks!
-Stephen
