Vacuum still works with wand, but brushes will not turn. It is not smoking or smells funny
There's a reset button down on left side of powerhead in the black plastic at base that corrects the problem of that red light
Thank you! It was hard to find the reset button, but that did the trick. The light came on after hair needed to be cut off from around the roller and the canister was full.
Awesome it worked!
I love this vacuum and would hate to have lost it
I had the same problem and had no idea about the reset switch. Thanx so much for posting your answer!!
SOURCE: beater bar brush stopped working...
Does the power head motor stop, or does the brush roll stop. If it is the brush roll stopping, replace the belt and/or the brush roll. If it is the motor, you may need to clean out around the motor, it may not be getting enough air to cool causing it to overheat and stopping. That the brush roll plate off, take out the screw, and the top will come off, then you can check to see if cleaning is the answer, if not, the motor may be bad.
SOURCE: brush roll belt stops turning when in position to
I think I know what the problem is with your machine. It's a rather lengthy repair, and I'll be happy to photograph it for you (like I do on most of my Fixya answers), but I'd like to know before doing all of that if you still need help, or if you've already fixed it.
Thanks,
CJ
SOURCE: Brush will not turn and lights will not light
the problm is under the top cover of the base,there are some screws on the botton also remove the self adhiesive emblem on the top and remove the screw then the top will come off.ithink what you will find is a burnt circuit board that sets right above the motor
SOURCE: Electrolux Vacuum keeps turning off and light looks like bag with
Turn the knob on the top of the vacuum all the way to the right.I had the same problem and that fixed it.
SOURCE: Eureka 4870 vacuum brushroll control doesn't work
Use two hands to presscontroll button upward until it snaps in place.
