Sirius Satellite Radio Receiver Logo
A
Anonymous Posted on Jan 12, 2013
Ford focus shows antenna fault for sirius how to fix
Am/fm works when i push sirius buttom it shows antenna fault i called sirius to activate but still shows antenna fault
5 Related Answers
Anonymous
  • 20 Answers
  • Posted on Apr 27, 2008
SOURCE: Sirius radio with xm antenna
Not advised. They have different resistance and are set up for different Sat signals. Chances are you will decrease the life of your radio if you get a signal at all.
A
Anonymous
  • Posted on Jun 19, 2008
SOURCE: connect sirius fm adapter to 2008 honda civic sedan radio
Yes. Factory installed radio.
Bubbabear64
Tim Babcock
  • 2794 Answers
  • Posted on Aug 30, 2008
SOURCE: Sportster 4
Shouldn't need one. Does the rear antenna connect to the direct FM box?
Anonymous
  • 95 Answers
  • Posted on Apr 15, 2009
SOURCE: Sirius satellite radio constantly shows "acquiring signal"
it could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
Anonymous
  • 5158 Answers
  • Posted on Aug 24, 2010
SOURCE: Starmate reciever (about 6 years old) shows
unhook the power to it for about ten to 15 minutes. hook the power back up and let it "boot" up. that should fix the issue
2011 ford fusion radio works. Can get stations in urban areas when I get outside those areas lose stations. If I try the Sirius it tells me antenna fault. Can an antenna go bad.
possible bad ground or connection on regular antenna on serius make sure antenna is there some radios come with the option but no antenna
6answers
No sirius id, no presets, all cleared... activation didn't help
You need to call sirius @ 1-888-GET-SIRIUS (438-7474) and they will remotly reset the radio for you. This has happened to me twice and this is the only way i have found to fix it.
2009 dodge ram , fm,am,cd,all work fine on radio. but when I hit satelite radio it shows channel 184 and there is nothing.
Is there audio on 184? It sounds like it just needs to be activated. Call Sirius with the SID #, and they can send a signal. Sirius' # is 888-539-7474
Just bought a car and it had hardwired sirius radio already installed. I called and activated it with Sirius radio and tried to get assistance from them on how to get it to work. They gave me instruction...
The "hard wired" version that you speak of apparently only refers to the power supply.Do you have a seperate display for the Sirius unit? Now, you failed to mention the type of radio (factory or aftermarket); so, if you have to use an "empty radio station" then you have an FM modulator. This modulator could wired or wireless. The wired version interrupts the vehicle antenna wire and the station on said modulator is usually preset to either 88.1, 88.3,88.7, or 89.1. There is no need to power this modulator up, it comes on when then Sirius comes on. One way to check for power is to turn on the Sirius unit and tune your radio to an occupied Fm station. Wait a few seconds and listen to the reception. Turn off the Sirius unit, the reception should improve for the occupied station. If it is a wireless FM modulator it also has preset stations that you can change but, extending the wieless antenna will greatly improve your reception of the Sirius stations.
2helpful
Hi i have a ford focus 1.6
This problem is caused by most commonly by a poor Antenna ground, and 2nd the radio chassis ground.
Sportster 4
1helpful
2answers
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
2helpful
3answers
Antenna hookup 2007 dodge ram
Just take the fakra connector (plastic piece) off and it will be just like the sirius antenna end. Then buy a 10ft extention cable... I've just order mine and will have pics when done
Top Sirius Audio Players & Recorders Experts
John
John
ZJ Limited
ZJ Limited
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
