whenever i am appliying any themes the message is themes currepted plz solve this problem online...
Solve
AnonymousMar 04, 2009
rtytdrtytd
You can't post conmments that contain an email address.
Did you save music files on phone memory? If yes , it is time to move it to your memory card. Also check for other big files that still keep in phone memory. If able , just move also your theme files to memory card. Move / delete also old messages files, games (if any), etc in phone memory.
Like computer, your phone need enough space for caching.
that theme may not be supported in your samsung set.By searching in internet you can get the themes supported in that set.Also the lack of enough phone memory can cause the same problem.
Install NOKIA PC SUITE into your computer now connect your mobile with the data cable and computer through usb port.After that start NOKIA PCSUITE and select option update phone software ,it will install the lates software/firmware for your mobile....................enjoy
You are unable to run animated themes on your mobile because you dont have the latest firmware/software for you mobile nokia 6270.
SOLUTION:Install NOKIA PC SUITE into your computer now connect your mobile with the data
software/firmware for your mobile....................now install animated themes on your mobile and check it.you will find animated themes working............enjoy
The error you are getting says that the theme can not be loaded because
theme service is not running, so to start the themes service press
WIN+R on your keyboard, type "services.msc" in the run box (without
commas) and from the list that opens, find the theme service and
start/enable it.
Solve
rtytd
