Battery and the AC cord attached same? Remove battery. Try another cord with the EXACT same power specs. Reseat the Memory Mods. Take a look at HP support : http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00372748&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=3807258
SOURCE: hp dv2000 won't turn on...
dude, I almost gave up.. try this link. Apparently lots of people experienced this problem so HP gave an extended warranty for models like these.
Here, more info: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us
To contact HP in North America call 1-866-671-7362 from 6:00 am to 11:00 pm MST, 7 days a week.
SOURCE: blinking power button, no responce from the laptop
sound like you charger is broken, i think tose use the same charger as the compaq presarios, evo's if you can get a used 65 wat that problem would have been fixed, but those are still pretty new, i think you can get a new charger for free if it's still under warranty
SOURCE: Won't Start or Charge, but charge icon blinks 3 times when power button is pressed
Try removing the battery and Turn on with AC power
SOURCE: no power when i press button...led fashes 8 times
remove and, reseat your memory if that doesn't help try disconecting your dvd drive hard drive(s) one at a time and, retest
SOURCE: hp 6820s will not power up.
Try removing the battery and see if the light is normal.
If so, you may need to replace the battery.
