Possible that the lock switch had broken or that the alignment of the lock is offset. You can remove the front panel by removing the screws on the sides and slide out the panel to get a view of the lock which wil confirm the case. If so the lock must be replaced or if broken and the piece is found within , it can be stuck together using instant glue.
Door catches.
One of the latches has broken off and
is not lifting the other latch clear of the housing. Remove from any
power source, remove the cover of the cabinet. Slacken off the clamp
mechanism and ease the clamp over the guide to allow the door to
open. When a new door lever is in place, the door may be easily
adjusted by slackening off the screws that clamp the door
catch/actuators in place whilst holding the door closed and then
tightening the screws. The rear of the door may be adjusted by
slackening the lower door hinge screws and adjusting as required.
I
hope that helps.
Door catches.
is not lifting the dother latch clear of the housing. Remove from any
I
hope that helps.
