The Toshiba Satellite A10-S169 includes several utilities to improve the performance or security of the computer, and to reconfigure the system's settings. Toshiba Satellites running Windows Vista 32-bit and Windows XP come with the Toshiba HDD Recovery Utility, which allows you to create a recovery CD of your system and applications. The recovery CD will allow you to restore your system and its settings in case your hard drive fails.
Click "Start." Click "All Programs." Expand "Hard Disk Recovery Utilities." Click "Recovery Disc Creator." Select "CD" as the type. Check "Recovery and Applications." Insert a CD into the disc drive. Click "Burn." The Toshiba A10-S169 will begin writing the recovery content to the CD. Follow the on-screen prompts to burn your recovery files to disc. Hope this helps.
SOURCE: Install windows XP on toshiba satellite U300
Hello
The windows Xp installation doesent find your hardrive because you have a sata drive. you need to adjust the settings in the bios so the sata drive appears as a ordinary IDE drive(ide native) or something like that. search in the bios settings.
A other way is to burn a new winxp cd with the Toshiba Satellite U300, sata drivers.
download the http://www.softpedia.com/get/System/Back-Up-and-Recovery/Barts-PE-Builder.shtml
and download the toshiba harddrive drivers and creat a new cd.
but the simples way is to make the change in bios.
good luck
SOURCE: windows xp drivers for toshiba satellite p205-s6307
I have a Toshiba P205-s6337 I have ran vista ultimate and Windows XP Pro with no problems. I took a while to get all the drivers but now that I have them I can upload them and share. If anyonw needs them just drop me a line and i can post a link. I did compress the files into a rar file that i split into2 parts. 1st part is 100mb 2nd part is 78mb compreesed with winrar at maximum.
[email protected] is the address if anyonw wants the drivers posted, I can host the files so it wont be a goofy rapidshare link
SOURCE: I can not install windows XP on Toshiba Satellite U300, windows
You must have latest Windows Xp CD .
Latest Motherboard chipset does not recognise hard disk without proper sata raid or sata driver. So you can install sata driver if u have USB floppy drive by downloading latest Sata raid to floppy. At the time of installation you will see a message press f6 to if u need to install raid driver.then press f6 asking for floppy drive and floppy insert press enter to continue.
SOURCE: i want lan driver for toshiba satellite pro a120
Go here, scroll down the page, enter the code in the box and download the LAN driver >>>>>
http://driverscollection.com/?file_id=37563
Regards.
SOURCE: how to install XP in toshiba Satellite L45-S7423 laptop
You cannot uninstall Windows Vista, but you can reinstall your previous operating system, which then replaces Windows Vista. To reinstall your old operating system, you must have the original installation disc. Back up your programs and files, insert the installation disc into your computer, and then reinstall the old operating system. To regain the hard disk space used by Windows Vista, reformat the disk during the reinstallation process. After reinstalling your previous operating system, reinstall your programs and files.
