how can i format my m2 memory card because when i try it on my phone it aleays failshow can i format my m2 memory card because when i try it on my phone it aleays fails
AnonymousMar 07, 2009
i need the code to format :( plz
AnonymousApr 08, 2009
where do i insert it in the computer where do i insert it in the computer
AnonymousMar 20, 2014
The adapter is recognized correctly, but it always reported 0 bytes on the M2 chip. I've tried other M2 chip and other adapter (same brand). Always the same...The adapter is recognized correctly, but it always reported 0 bytes on the M2 chip. I've tried other M2 chip and other adapter (same brand). Always the same...
You can't post conmments that contain an email address.
#1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com #2 Open up 'My Computer'. You should see it under the list of available drives. #3 Check its contents first to make sure that you have the right drive. #4 In 'My Computer', right-click on the drive and choose 'Format'. #5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place. #6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
Did it work earlier? Try reformatting it (caution: you will lose all data on the card!!!) and make sure you format it with FAT32 filesystem, NOT NTFS!
You can do the formatting from windows by right-clicking the drive icon in "My Computer" and selecting format.
A lot of phones have a format option (refer to your user manual for that). It's even better because that way you're sure that it will have the proper filesystem.
1. If your memory card can be detected on your computer, then try to completely format the card.
2. Goto Start >> My Computer >> Right-Click the memory card icon >> Format >> Uncheck the Quick Format option >>
Start >> OK / Yes (confirm the request!).
3. If the memory card cannot be detected / readed by your PC, phone, or camera, then that card has become corrupt / unrepairable!
4. You should replace that memory card with a compatible one!
You need to isolate the problem. Try connecting the Sandisk M2 into another phone or computer (using an adapter). If this memory card is detected by other phone or computer, then you may want to insert another memory card into the problem phone to test it.
If the problem phone works using another memory card, but the problem memory card also works using another phone, then you may want to format first your Sandisk M2 before using it.
This may have something to do with how the m2 card is formated. PC systems such as FAT32 and NTFS do not work with cameras or telephones as the data cards in these devices are formatted to FAT16 or lower. In order to read the card when you placed it in your PC FAT32 would have been used.
If you are prepared to loose the data on the card I suggest you use a PC to re-format it to FAT16, your phone should then recognise it again!
I was facing the exact same problem with my W200i. I formatted my memory card using the "Quick Format " option and then re-uploaded my songs. That solved my problem. There is no disturbance in between songs now, also the "Playback Failed" error has also not occurred again.
