Grab the upper and lower conic sections, one in each hand. Twist the lower section clockwise to remove from the upper section. The filter is in the section - remove and empty, then replace and twist back to close and lock.
Pete Galati you need a spelling *manual.unless you're directing your comment towards *Manuel and, in that case use a comma however I don't see him here. Also you need a cap Ctrl button, because your name is not that important!
SOURCE: how do i open my
remove vac from charging base. twist the two section apart. it will turn about 1 inch and then pull apart. this will expose the filter to remove to empty the dirt. reassemble in reverse.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
