GE Monogram ZISS420NRSS 42" Built-In Side-By-Side Refrigerator (ZIS-S420NRSS, ZIS S420NRSS) Logo
Importacion de Equipo Invesa Posted on Jan 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am looking for G.E Monogram parts.
I need the Circuit Board for GE Refrigerator Monogram model ZISS420DRISS.
Thanks for your answer
  • 2 more comments
  • Anonymous May 11, 2010
    You have 2 boards. Which one do you need ?
  • Anonymous Mar 26, 2014
    Model#zfsb27dagss
    Model#zfsb27dagss
    serial#az218345
    model#zfsb27dagss
    serial#az218345
Anonymous
Level 3:
  • Master 410 Answers
  • Posted on Jan 21, 2009
Anonymous
Master
Level 3:
Answers
410
Questions
Helped
229432
Points
1392
Here ya go you may be able to find it cheaper looking around on the internet as well the part number is WR55X10560
There is a control panel reset for my GE Monogram side by side, Model # zfsb23dnss, It was "repaired" with a new board and now will not cool or freeze, HELP
There is no such button. What part # was on the replacement control board? Your model also has an INVERTER used to control the compressor... When the machine is turned "on" does the fan in the freezer and the fan near the compressor run? Is there any frost on the back wall of the freezer, or is it room temp? GE Refrigerator Main Control Board WR49X10152 .... GE Inverter Board WR49X10283 These two parts control compressor function on your fridge, the first two are the expensive parts called for by your model number- the second two are identical function, but cheaper part number!
1helpful
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Ziss420driss ice maker
Hello there... what is the make and model of your ice machine?
Ge monogram won't turn on?
Thank You for providing the model number so I was able to see what parts your refrigerator uses. Some models like yours have something called an inverter board, yours does not. Fans not working properly can also bring a heavy load on compressor causing the compressor to heat up and damaging the motherboard where you hear the clicking.The problem you are having is possibly related to the=> WR07X10074 Start Relay, e=>WR08X10052 Overload WR62X0080 Run Capacitor, and the=> WR55X11130 Main Control Board Here is another board sold at Appliance Parts Pro's=> WR55X11130 Main Control Board Assembly If you would like to do this yourself I will be glad to help answer the questions you have even assist you with installation questions. The problems you are having i typical for GE Refrigerators. If you have questions I am here. Thanks John Tripp Appliance 911
Contact me HERE
ZIss420DRISS compressor is very hot
In regards to all the answers above, where did u guys get the answers? It is totally off. U guys should know the correct answer n know what u r talking about before u attempt to give it. Check the model #.
Fyi, with this particular model, the compressor is on top of the fridge, along with the condenser, condenser fan. The evaporator is right on top of the freezer. A drain pan is under the evap, when in defrost, water drains over to the pan under the compressor to the right.
So for all u 'technicians' out there. Check ur knowledge n answer before u give it. It'll help the consumer much better!
1helpful
Defroster not working
The WR51X322 Defrost Heater Assembly
could be burned out in your model. Can you look inside the fresh food section and find the model number for me. The answer to the problem on your model depends on having the correct model number so I don't miss other parts that may cause a defrost failure. I know you said Monogram Side by Side but that does not tell me for sure what the Model Number on your refrigerator is. If your model is like the models in the GE Monogram Refrigerator Service Manual the I can have an idea of those parts. Those models have the defrost controls as part of their motherboard and that board does not fail at least in the defrost part of the board. defrost very often. You may need to also test or replace the WR50X10088 Defrost Thermostat I will be here should you have questions Thanks Sea Breeze
Compressor stopped working, ge side by side
Can you cut the inverter open and look at the board for swollen capacitors or burn marks like these HERE Here is one of my earlier post about a=> 48" GE Monogram ZISS480NRISS Refrigerator It may be necessary to order both the motherboard and the inverter board for your model and return the parts not needed. WR55X10490 Inverter Board
3_22_2013_9_04_47_pm.jpgThanks I will be here to answer any questions you may have Sea Breeze
GE Monogram ZISS420N - Freezer works fine - refrigerator side is also freezing with thermostat set on 45 - repairmen (if you want to call him that) on five seperate occasions replaced thermostat,...
We are GE Monogram factory authorized service & parts and this issue sounds like your control board to your fresh food has gone out. The control board controls all the parts on your GE Monogram. You can contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
for all your appliance service issue and to get your parts.
We hope this solves your issue and we look forward to working with you.
1helpful
GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Top Refrigerators Experts
vince
Johnny 1000
