Question about Canon EOS Rebel Ti / 300V 35mm SLR Camera
When i look through my lens, its blurry
When i look through the lens to take a picture its very blurry, but when the picture comes out, its not blurry at all. How do I fix it where i can see clearly through the lens?
  • Anonymous May 11, 2010
    Exactly what do you mean by blurry?
    Do you wear glasses?
    Are you lightly pressing the shutter release while framig the shot?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Canon Master
  • 102,366 Answers
Adjust the viewfinder diopter to suit your eyesight. The control is near the viewfinder; try adjusting it and see if the image clears up. Be careful not to poke yourself in the eye as you do this.
Posted on Jan 16, 2010
Anonymous
SOURCE:
Blurry webcam
Many laptop computers come equipped with a small web camera assembly mounted above the LCD screen. Like any other camera, these webcams use a lens to take pictures. Over time, it is possible for this lens to become dirty, especially if you have touched it a few times. You can quickly clean the lens and get the unit back to taking crisp pictures.
1.Take a microfiber cloth and gently press it to the lens of your laptop's web camera.
2.Gently rub the lens of the web camera with the microfiber cloth. Be sure that you cover the entire surface of the web camera's lens.
3.Open your web camera program when you are finished and take a picture to test the quality of the webcam. If it is still blurry, close the program and repeat steps 1 and 2 until the web camera is no longer blurry.
Sep 09, 2011 | Cameras
Got no picture all blurry
No picture or one that is all blurry? If blurry,
Clean the lens and make sure it is not loose or damaged. The camera cannot produce blurry pictures at distances greater than around 0.3m ish as it has a fixed focus lens. If it really is blurred either you are too close to the lens, the lens to sensor distance is wrong (mechanical damage) or the lens is dirty.
I hope that helps
Jan 26, 2011 | Microsoft VX800 Webcam
I JUST got a Nikon Cool Pix L22 but no matter what setting I use EVERY picture is blurry. I am an art teacher and understand shutter speed and aperture, I even used a tripod. The pictures are still...
Most likely your fisheye lens attachment is out of alignment. An internal element may have come unscrewed or unglued. The other option (I'm assuming you have already checked this) is that it is incorrectly attached to the camera - check your threads and make sure it wasn't cross threaded and that there are no blockages to the lens attachment being screwed in completely. If the fisheye lens is not in the correct position relative to the CoolPix lens, then the pictures will be blurry.
Nov 21, 2010 | Opteka Full Fisheye Lens for Nikon Coolpix...
Blurry images
If it is brand new, return the camera, and show what is happening.
The blurry pictures has to do with a few things. A damaged lens system, a dirty lens, other damage to the lens while it was extended, water or moisture damage can also cause this, including internal circuit damage or broken parts.
Make sure it has not had an impact or other damage, because if it had, then more than likely you will have no warranty, and it will not be taken back by the store.
Oct 25, 2009 | Cameras
Pictures turn out blurry..why?
One of the internal lens assemblies has probably come loose inside the lens. It happens often when the camera gets dropped. It requires major disassembly of the camera to get the lens unit out to work on it. Usually costs around $68.50 to fix.
Bob Kilbourn
www.CameraRepairs.com
Jun 28, 2009 | Canon PowerShot SX100 IS Digital Camera
Every time i take a picture with my nikon d-40 the pictures are blurry. the camera is on auto focus but i can't seem to get the picture to come out clear. any suggestions?
Is your shutter speed fast enough? If not, you'll need a faster shutter speed or a tripod.
Are you using the proper focus sensor? Is the entire image blurry or just portions of it?
What happens if you focus manually? If it comes out sharp, then there's a problem either with the lens or the autofocus system on the camera. Have you tried it with a different lens?
Is the AF switch on the lens set to A?
Jun 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
My Casio EXILIM EX-Z70 Digital Camera turns on and take pictures and everything but the pictures come out blurry. Any way I can fix it ?
Make sure the lens is clean. Exhale on it and wipe carefully with a lens tissue. You also may want to set the "image quality" setting to "High."
Apr 28, 2009 | Cameras
The screen beeps and show E61:00. The pics come out blurry. HELP!
yes.its the lens error for sure.either the lens is dirty then needs cleaning.or the lens is got dirty plus lost its allignment then it needs allignment or replacement.
thanks.
Dec 15, 2008 | Sony Cyber-Shot DSC-P51 Digital Camera
Pictures come out blurry
change your settings, set the image size to a higher number. and select "best" on picture quality
Nov 24, 2008 | Cameras
Trouble with sony cyber-shot DSC-T33
try cleaning the lens first.
when taking the picture press down lightly so it will focus. Then press harder for the picture.
Jul 14, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Canon EOS Rebel Ti / 300V 35mm SLR Camera Logo
415 people viewed this question
Top Canon Photography Experts
old marine
old marine
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Canon Photography Expert? Answer questions, earn points and help others
