i can make my mp3/mp4 player in my pc i am using windos vista and when i tried to download the cd, it tells me is not compatible. what can i do?i can make my mp3/mp4 player in my pc i am using windos vista and when i tried to download the cd, it tells me is not compatible. what can i do?
have a similar problem. I can plug the USB cord into my Windows XP machine and load the drivers from the disk. Then I can then move music, pics, & video to the device. I have tried the following version of the software with the same result: mp3set1.45, mp3set3.75, mp3set4.00, mp3set4.04 I want to use the UPGRADE feature because the "music player" software kind of stinks. I use the device for listening to audiobooks, and the built-in software doesn't keep track of where I left off. It just restarts the last mp3 file played. That's no good for audiobooks because the play time of the audio files are long and it's hard to remember the exact time stamp that I left off. I wish there were a way to "flash" the device with a different firmware. Has anyone been successful in hacking the actual operating system of these devices? I have friends would might be able to re-program the entire interface if they could get the original ROM software. Any tips?
AnonymousMar 16, 2009
i use a cubemp4 p300
when i plug is show charging
and no data drivei use a cubemp4 p300
and no data drive
AnonymousApr 27, 2009
i have the same problem
You can't post conmments that contain an email address.
Hey all here is a modded ipod software for but i need help if some one will help me ill give it out but a dont no how to acces the hidden partion reward also !!! available
A little weird, I think you should contact the rockchip mini projector after service. if they can not solve this problem, you can convert video to wmv format every time.
This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions. 4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met. - Windows XP SP2 or higher - Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player. - Download the hotfix from http://support.microsoft.com/kb/939211. - Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager 1. Right-click My Computer, and select Manage. Image 2. Click Device Manager on the left pane. Image
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes: If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting. - Try connecting on another computer. - Try using a different USB cable - Try connecting to the back USB ports which may supply better power. - If only MTP mode is not working, try reinstalling Windows Media Player For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Maybe you need to install some driver, check if your product came with a CD driver or search for the web site of the product. You need to post more information about this mp4 player to help us to help you.
i have a mp4 player brand name ikasu now it is not being reconised in the usb drive i have lookin in the secotion computer nd it hasent *** up it dosent say any thing usefull in the manual and clearlyt doesent have it in my windows media and when i plug it in it starts chagin when i also dont know how to get music on it i have windowns media player and i am on vista home premiare i dont have a clue how to get music on any ideas ?
Please help me
Please can anyone also help me, The disc is useless (I dont think its for Vista)
Thank you.
dude, mine does too
and no data drive
