Asko T721 Electric Dryer Logo
Jennifer Tiberio Posted on Jul 02, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Asko T721 Electric Dryer is having drying troubles
The dryer only dries when you hold down the start button. when you let go, it stops drying and does nothing, what can i do to fix it?
  • 1 more comment
  • Jennifer Tiberio Jul 03, 2007
    I'm not quite sure how to find the circuit board you are talking about, would we have to open up the machine? please explain, thanks!
  • Jennifer Tiberio Jul 06, 2007
    where can we get a service tech? The company won't help us cause we bought it used.
  • SheraOne Dec 29, 2008
    I cleaned the filter and I found the fuse but nothing happens when I push it in. It's actually rubber like. Is this the right piece?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
672
Points
5
Here's the answer:
The dryer has a thermo protection "fuse" that pops-out when the lint filter is not cleaned and air will not flow properly. When the airflow is restricted the dryer gets too hot and the "fuse" pops. Then it will not run unless you stand there and hold the start button in. As soon as you stop pressing the button the dyer stops running.
Clean the filter ESPECIALLY the "internal" filter. This one is behind the lower skirt of the machines face. There are two Torex head screws (T20) to be removed and the skirt comes right off.
Inside you see two red handles that you turn to open the filter door. Open the door and pull out the filter. It is a long metal finned box. Take it to your bathtub and run a ton of water through both ends to remove the lint inside. You'll be surprised at how much.
O K now let's "fix" the "fuse". Here it is likely you will need to pull the machine away from the wall. The fuse is a black plastic button about the size of a penny. It sits in the center of the machine's backside. It faces up a bit and if you have clearance you can reach your arm over the machines top and press it "in" with a finger. It clicks when you do so. This part is a no brainer. The dyer will now start properly.
The hard part to all of this is pulling the machine away from the wall since like me you probably have it sitting on top of an Asko washer. Take your time. You can do it.
Anonymous
Level 1:
  • Posted on Sep 08, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
672
Points
After cleaning the internal filter as well as the fan and checking the fuse it turned out it was an issue with too much water in the drain pan directly BEHIND the internal filter. I used a sponge to soak it up, put the filter/cover back on and my clothes are finally drying. Bonus though...taking off the fan and resetting it stopped an annoying squeaking!
Anonymous
Level 1:
  • Posted on Aug 21, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
672
Points
I had this problem where the dryer would only run if I held the button.
I removed the internal filter (the one you seldom clean that is only visible after you remove the bottom front panel and follow the pictured directions to turn the red handles). I cleaned the filter according to the pictogram, flushing it (a lot) with water in both directions. Make sure you're flushing the water into an area where you don't mind there being lint at the end.
That didn't fix it, but per Knash42's directions I sopped up the extra water in the area behind there the internal filter goes with a sponge. Took about 5 minutes and worked great.
I didn't have any luck holding down the button, but I also didn't have to access the back of the machine.
Anonymous
Level 2:
Sergeant:
  • Expert 351 Answers
  • Posted on Mar 03, 2008
Anonymous
Expert
Level 2:
Sergeant:
Answers
351
Questions
Helped
167407
Points
619
You may find that thers to much water in the dryer when you hold the start button in the drain pump will come on and drain the water out,then the dryer will work ok
Anonymous
Level 3:
  • Master 883 Answers
  • Posted on Jul 03, 2007
Anonymous
Master
Level 3:
Answers
883
Questions
0
Helped
748268
Points
2537
There is a relay that has failed. it can be replaced. look for a rectangular part (plastic) on either a circuit board or mounted separately that has wires (or pcb traces) leading to or from the push button. The relay "holds in" the switch electrically when you release the switch. if you cannot find the relay, I can give you more details on how to add your own relay...just tell me how many wires to/from the switch.
  • Anonymous Jul 04, 2007
    yes, the back panel must be removed (remember to remove power) to access the control section, which can be either a circuit board or discrete components wired together. If you are not confident to attempt this, contact a service tech.
  • Anonymous Jul 07, 2007
    I believe I may have found the trouble, but I believe I am not a service-tech finding expert...sorry.
My dryer won't heat up to dry the clothes. I empty the condensing unit (the long many paneled pull-out piece behind the two red levers behind the lower front panel) periodically and this is not the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Dryer will not dry clothes
Didn't I just answer this question?????
Check your exhaust duct to assure it is absolutely clear. If yours is a machine that has driness sensors, clean them according to the manufacturers instruction.
Thank you for your question @ FixYa.com
No heat not drying
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
My asko T721 dryer won't start. If I hold the start button down it will work, but the second I let go of it the dryer stops. It was running fine yesterday and then it stopped and now I can't get it...
the start button is bad. you will have to get it replaced take the model and serial# and go to your local appliance part store and they should have one.
Was drying a load which strated with no problem. About 10 minutes later the unit was off and not running. Open door to check if clothing was dry and done and it wasnt. So I hit the start button and it...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
4helpful
2answers
Overheat trips Asko T721 dryer
If you have a condensate tank that fills up too much the float inside the pump housing will shut the dryer off also.
Dryer wont turn on
The dryer has an overfill cutout if you start and hold in the start button you should hear the pump come on,and pump the water out. then the dryer will start.if it happens again you may have a blockage in the black drain hose take the top panel off and blow down it,or the pump itself could be faulty.(if the dryer is sitting on the floor you have to drain the water into the drawer, if its mounted ontop of a washing machine you can connect the long bkack hose to the sink.
Top Asko Dryers Experts
Mat Kramer
Mat Kramer
Level 1 Expert
Paul Carew
MattS1978
Level 1 Expert
Are you an Asko Dryer Expert? Answer questions, earn points and help others
