Computers & Internet Logo
Posted on Jan 21, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IR 5000i and iR 6000
1. my IR 6000 show E00061-0001 or E00061-0002 after it is fixed by a technician. Actually it runs well for the first time, except it always gave black spot at the left-bottom corner of A4 or letter-sized paper. But if I set them to R position, it's OK. Then I asked them to be repaired but now the error code above is appeared and I can't even use the machine. What do you think about this?
2. my IR 5000i is turned off for itself and after I turn it on, it shows E00002-0000 code. I try to turn it off and then turn it on again but no effect however. What is this means?
  • danar308 Feb 15, 2009
    Thanks for answering. My 1st problem is resolved. It happens to be the
    technician I once hired was not careful when placing a conector back.
    He broke it and that's the main cause. I called another, they replaced
    it and it is solved. The black spot was because the lamp was misplaced.
    After it was fixed, my machine is running fine now.
    And about my 2nd problem, it sometimes shows me E00002-0000 code, and
    sometimes it doesn't. At the screen, it was hung at the Canon logo
    condition, and can't enter the main page display. They told me it was
    probably because of the main PCB controller faulty. BTW, just curious,
    could it be possible if it's because of software problem?
    Thank you
  • NSIVAREDDY1 May 10, 2009
    E002
Anonymous
Level 2:
  • Expert 100 Answers
  • Posted on Jan 21, 2009
Anonymous
Expert
Level 2:
Answers
100
Questions
0
Helped
62160
Points
147
1 needs a new potential control sensor and pcb. this needs to be installed by a certified tech, However it can be the laser that needs replaced. The procedure isnt fun, this is a difficult problem to resolve.
2. this just needs a new thermistor sensor for the fixing unit. that part shouldnt cost more than 15 bucks. If fixing unit is worn past its life it should be replaced.
  • Anonymous Feb 15, 2009
    e002 error is a fixing unit error. This is the fart in the middle that gets very hot.
    The main board is not bad thats a little dum thing to say. The first thing to check is if the fixing rollers are dirty and worn out. This can happen anywhere between 500 to 1 million pages on the machine. Open the drawer and open the left side delivery assem as if you were removing a jam there. look at the rollers, if they are good your copier most likely needs a new main thermistor.
    Have them install a main thermistor and reset the code. inspect fixing unit and give tell you when it has been rebuilt or how worn out it is. Canon suggest rebuilding them every 500k pages but some can get 1 million if they are used in a heavier manner, like at a big cherch that would use it a lot. Gee I wish I was getting paid something for this lol
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Oct 19, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1308
Points
My IR 6000 show E00061-0001 or E00061-0002 after it is fixed by a
the machine.
picture was pale
Is iR 5000i & iR 5020 LCD Panel same?
they are the same the ir 5000,6000,5020,&6020 are the same
Error Code...
Problem 1 is most likely a problem with the primary corona unit... The grid wire is arching to some part of the unit - it code also be that the post wire are strung to loose and the corona wires are bouncing and arching. It sounds like there is something wrong with the corona unit. Have them change the 2 post wires and make sure the grid is clean and that none of the wires are crossed.
Problem 2 A E0002 is a fixing error code. It means that the fuser is not heatting up in time or that is not turning "ON". Most likely you can clear it in service mode, but if that dose not work it could be a blown thirmister or thermal fuse or the fixing lamps or all 3. If it can be reset, the problem may be a power problem from the outlet. Good Luck......
3helpful
4answers
Printing envelopes
Dear all,
Im interested this model canon IR-2800/ 2200 /3300 /7200 /8500 /105 /6800 /6000 /5000 /600 /400 / 6020 /5000i /G.P 605/405/ CLC 1140/1180/1120/1100/1150 please kindly quotes us...Here my email add. [email protected]
3answers
PLEASE HELP ERROR CODE
The machine's hard drive has died. you will need to get a Canon technician out to replace it for you and to re-install the machine's system software. In addition to this you will also need to reconfigure some of the machines settings such as the address book, as this is usually lost when the hard drive is formatted or replaced.
2helpful
3answers
Error Code description
The Canon is coming on with a code E602-0003 can somebody please help it is only 9 months old and the company we bought it from is out of bussiness. Please email me @ [email protected]
Thanks
Madlyn
24helpful
4answers
ERROR c-6000
Hi, enter 10871087 on keyboard of machine, then enter 163.After that press "execute" and start button.machine will restart and will be ready to copy.Otherwise,call service.
BR
15helpful
3answers
Error code on screen is E602-0003
i have problem in my cannon ir 3320 it shows
E602-001 & E0315-000d
pl solve it
Top Canon Computers & Internet Experts
old marine
old marine
Steve Sweetleaf
Steve Sweetleaf
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
