JVC AV-48WP30 48" Rear Projection Television Logo
Posted on Aug 26, 2017
58" JVC I-Art Rear Projection - no blue, green and red only
After a move, there is no blue colur. I changed the HDMI cables. Still no blue. Tried convergence. No Blue. What can I try?
Me again... The convergence screen is showing a blue gun up at the top. I looked in the back and the blue projection bulb seems to be working, but maybe not as well as the other two colours (not as bright?)
This is for the JVC I'art AV-48WP55
  • Anonymous Mar 07, 2009
    I lost my red it looks like the red is dripping in the lower right and upper left corners
5 Related Answers
Anonymous
  • 156 Answers
  • Posted on Jan 01, 2008
SOURCE: jvc av-48wp55
Replace the IC power STR.s6709 and
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jul 27, 2008
SOURCE: I ART PRO JVC 56
You will need to replace the convergence iCs there are two of them they are both STK392-110 Ics you will also need the JVC convergence resistor kit. You can get the ICs and resistor kit at the following link and they provide free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Aug 14, 2008
SOURCE: re: I art jvc
you can get the convergence repair kit to fix your model JVc at the following link look under the convergence repair kit category, they provide free step by step instructions with pictures so you can easially do the repair yourself. heres the link.
JEfromCanada
  • 59 Answers
  • Posted on Jun 18, 2009
SOURCE: jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Anonymous
  • 90 Answers
  • Posted on Jul 08, 2009
SOURCE: red convergence will not line up on my jvc 56 inch
You need to pull the front grill cover/panel off the front of the tv. Remove screws (4) from back that hold it on, also 2 small ones behind front video input door. Then remove access panel. The ckt board closest to you is the convergence amplifier board. You should replace both amplifiers (stk392-110 or 120) and any burnt/open resistors you find near the amps.(use the same value resistors as the corresponding resistors in the blue amp ckt)
1helpful
Black and white picture with red lines vibrating with sound.
More info would be nice. Are you using HDMI or Component cables. If it is component cables (red, blue, green for video white and red for audio) Check your red and blue connection. Green alone will give you a black and white picture.
If you are using an HDMI cable, replace the cable to see if this changes anything or if you have another tv swap cables to see if problem stays with tv or moves to another tv.
The convergence fo the blue color is lock on my JVC TC
The blue is not locked it is set. It does not move, the other 2 colors, red and green, are supposed to align with blue.
4answers
How can I attach an HDMI BluRay player to my TV
Blu-ray attaches to component inputs. Component cables are the red-green-blue cable and the red and white for sound.
Out on the blu-ray to 'In' on the TV.
Here is your owner's manual. see page 19
How to hook up xbox 360 to jvc dlp thru hdmi ports
You can use an HDMI-to-DVI cable for the TV's DVI input and this would give you video at full HD 1080p resolution but you need to route the audio via standard red & white RCA. It would be better if it has digital audio inputs such as optical or coaxial to get Dolby Digital and other digital formats from your source.
If in the unlikely scenario that it does not have a DVI input (which looks similar to your PC's blue VGA only wider and is white) you can hook it up to your component video-in (which is the red/blue/green RCA inputs). For this you need a cable that has HDMI on one end and red/blue/green for video RCA's +red/white RCA's audio.
This would give you 1080i resolution with stereo audio.
Hope that helps.
No owners manual can't get new blue ray dvd player to work on tv
Here is the manual:
http://www.hdtvsolutions.com/pdf/JVG%20HD52G56G.pdf
When using the HDMI connections you may have to tell the DVD to output to that port.  Also you may have to connect additional sound cables from the DVD output to the TV.
JVC HD-61FN97 rear projection TV does not have any blue colors showing.
your blue componant cable is unplugged, eather on the tv, or on the cable box, 95% thats the prob, thats if you are using componant cables, those are red blue green, and red white for the audio
Jvc pos
when in manual convergence hit the select bottom to change to blue. as of green i have no clue.
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
Convergence problem???
you must move red and blue lines into the green. change red to blue by useing the select button on the remote. till all convergance lines are white
3answers
Samsung rear projection sp42w5hfx convergence problem
Compare IC connections with meter = check solder joints to
see if some are touching one another. Tell me exactly what
brand & part number was installed...........T.
PS. The red,green,blue plugs may be mixed up because the green should stay and red & blue move !
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
