SOURCE: homelite chainsaw carb adjustments
bear973 you must make sure that that in tank filter is seated in right position and not just floating around inside the tamk
SOURCE: my homelite super 2 chainsaw keeps flooding. it
Needle valve in carb. maybe hung open. Or diaphragm may be bad. You will need to remove carb. and clean and replace all worn parts. Go to homelite.com to find manual for the saw.
SOURCE: Homelite Chainsaw UT10901A Owners Manual
Hi
This is the closest I found on the net .
hope it helps .
http://www.partsmadeeasy.com/manuals/6164.pdf
All the best and good luck
SOURCE: Need owner or service or both manuals for Homelite
I haven't found a location of the operator's manuals but the numbers you provided made the IPL (exploded parts list) easy. Thank You. Go here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; In the "Model Name/Number" type in "UT-10654" and you are there.
Atta boy/girl
Lou
