Please email manual of e2h600 to [email protected]. Much appreciated!
SOURCE: using the oven timer of a Stove oven circa 1999
The normal STOVES label is on the rear of the oven, but there should be a small label visible on the left hand side of the lower oven when you lower the door. There should be a long product number on that with the unit serial number. The product no can be used to identify the unit. STOVES may be able to help here.
I have a 720EF handbook scanned and it is on my BT Digital Vault, so if you want this version give me a valid email address and I will ensure you receive a copy.
SOURCE: where can i get a operators manual for a stoves
If STOVES are not able to help at all, then ask them what the model number is. With that information you may be able to locate a handbook.
SOURCE: I have a Stoves double oven, but do not know how
I have posted this a number of times. Please look at other answers to obtain the info.
SOURCE: need to adjust clock setting
Press + and - at the same time (manual says hold for 3? seconds) and then + or - to set the time. If from power up, as I did yesterday, I don't think you need to hold them together for any length of time, but maybe it was my imagination, since I tried it first before I read the manual.
SOURCE: Stoves E2H600- lighting behind fascia
A bit involved but quite straightforward.
Open the grill door and you will see 4 screws on the underside of the hob - remove the inner 2.
You can now hinge up the entire hob.
On each side of the hob is a trim piece with 2 screws which retain the glass front panel. Remove these and the end trims.
Carefully pull the timer buttons away from the fascia - the simply click into position.
The glass panel can now be tilted up and removed - it is pocketed at the top.
Each of the control knob assembly can then be easily pulled away from the controls.
The fluorescent tube is situated below the controls in a recess.
Rotate the tube through 90° and lift the tube out.
Refitting is the reverse of the above procedure.
