Clock works, timer counts down however, my LG microwave oven model lma1180ST will not come on unless I gentle press on my door latch button
SOURCE: directions
You can find your manual for free download here.
You will need the free
Acrobat Reader
to view or print it in case you don't have it already.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: my GE 1660 profile microwave oven will not cook or
Check the door safety interlock switches. If they are burned (because you frequently open the door while the oven is running) they tell the magnatron that the door is open (forget what you know about the door) and not to run that magnatron (which produces the microwaves that actually heat the contents of your oven).
Check the switches with a ohm meter. Remove the cover to find the switches near the door latches.
Thank you for your interest in FixYa.com
SOURCE: Microwave Oven EM-804T
When I opened up the microwave cover, noticed that the door latch mechanism was worn and not holding up the interlock switch. A thick piece of tape on the worn piece of plastic and microwave was back to working (I had symptom of the timer counting down without the microwave turning on)
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
