It is and old DVD from waltmar in canada, i lost the control remote and now i dont know which on i can use or the codes for an universal remote control
SOURCE: Diamond Vision DVDV806-03 universal remote code? to set up ZOOOMS game remote.
found it...zoooos.com had updated their code list and works now.
SOURCE: code for universal remote
This must be a duplicate post. And because I'm not sure which one you'll check I'll just post the answer here too... Diamond vision is a little pickey with handing out their code access. And Rogers doesn't have a whole lot about accessing components like DVD players. But try this: 1. Turn on DVD player 2. Press the AUX button at the top of the remote 3. Press and hold the SETUP button until the LED light blinks twice. 4. Press 9-1-1 in sequence, the LED will blink twice again. 5.Aim the remote at the DVD player and slowly alternate pressing POWER and AUX. Stop when DVD turns off. 6. Press SETUP to lock the code in memory. It may take several minutes of alternating between POWER and AUX to find the appropriate code - be patient... If after ten minutes you haven't got it try programming it as a VCR - steps 1 through 6 above and substitute VCR for AUX.. Good Luck Bill
SOURCE: code for remote / Diamond Vision DVD Player model: DVD807-04
I found the code! It is 0736. The company is now called AudioLogic.
SOURCE: Diamond Vision DVD Player 803-04
call number of back of manuel and they can sent you one for 12. If you need number you can message me or look it up,
