SOURCE: Frigidaire Dehumidifier gives F2 error code and no longer runs.
ACCORDING TO FACTORY-NO SERVICABLE PARTS AVAILABLE
F1 is room temperarure sensor error. F2 is tube temperature sensor error.
The room sensor usually is located in the front of the condenser. The tube sensor is usually plugged in a tube near the condensor.
The tube temperature sensor (thermistor) should be about 10K ohms.
SOURCE: Frigidaire dehumidifier error code F2
Hello - Typically error code F2 indicates a sensor failed has occurred on the dehumidifier. You may want to contact your manufacturer to verify if the part is available and can be replace. Some do, some don't. Also confirm if the unit has a limited warranty on such concern.
