Please help me in order to solve the problem of one cassette is stopped and cannot work but the massage appear in the screen tell me please call the technical repair
Co920 - 1st cassette problem
Co910 - 2nd cassette problem
Co900 - 3rd cassette
Co950 - 4th cassette
Open and close the front after copier is ON,if the message is apper enter in the service mode,or pull out the cassette failure and work.
Service mode enter:press STOP - 0 - STOP - 1
Check the actuators in the cassette,feed rollers and the sensors.
SOURCE: Copies shows: Call Maintenance M2
Hello, the error code M2 means that the machine needs to have maintenance done ( like tune up to a car).. The only way to clear it would be to reset the counters and the service tech mode.
SOURCE: code c 0200 minolta cs pro ep 2050
A c0200 deal with the scanner. You may have a blown scanning lamp. Dose the scanner find HP & does the scanning lamp turn "ON" it could also be the Lens HP. Was this code before or after you were there? If it was showing upafter you.. it could be that the Black Box is installed wrong.... Good Luck
SOURCE: i have a Minolta CS Pro EP 1031 Printer that makes streak marks
Drum cleaning blade has gone bad. Especially true if the streaks seem to get progressively worse as you run multiple copies. In other words run 10 copies. If the last one out is worse than the first one out it is the drum cleaning blade. Cheap part...around $25
SOURCE: how to clear M2 on minolta EP 4000/5000 cs/pro copier
how can i clear m3 code on minolta 4000 copier
