Remote is universal Zenith. Mute button displays on sceen propewrly but has no effect. Can't find any reference to "Sound Off/On" when using remote. Only reference to audio is 'Stereo/Mono"
SOURCE: turning the sap off using my universal remote
If there are any menu setting buttons on the t.v. itself then I would try using them to find the sap setting.
SOURCE: no sound gpx klc8806dt
Hello, i have fixed a few of these units, Mainly the problem is, is the crappy design inside, take out all of the screws from the bottom of the unit, be careful when pulling the top cover off cause the battery unit on the side is detachable and could be stuck and u can rip the wires off the system board. now you will see the 2 speakers, take a razor blade and carefully cut away the glue that holds the speakers in, and there may be little white plates with 2 screws that hold the speaker down also. Now take the speakers out and test them on a home entertainment center or a cd player that has red and black connectors for speakers in the back. See if they work first, if they do carefully reconnect the speakers to the motherboard and reseat the connectors back in with ease. try the unit again. if it doesnt work check the solder joints where the connectors attach to the motherboard, sometimes they will come loose. From my expierence with these units is they tend to jam the speakers inside so tight that they eventually stop working, so be sure to only use the connectors to hold them in.
SOURCE: Lost instruction book for universal remote
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
HERE'S THE ANSWER TO YOUR PROBLEM:
There are times that TV sound problems does not require you to call for a technician. Some TV sound problems are just easy to repair, and you can just do it yourself. Try to do this one:
1. Press the "Mute" button on the
remote control or press the "Volume Up" button. The most common cause of
no sound is accidental use of the television's "Mute" function.
2. Make sure the speaker source
switch on the back of the television is switched to "Int" if you are
using the television's speakers and "Ext" if using surround sound. If
not set properly, you will not hear the television sound.
3. Access the television's equalizer by pressing the "Menu" button,
selecting "Sound" and then "Equalizer." A list of sound options will
appear on the screen. Use the up and down arrow buttons to select the
option you want to adjust, and the right and left arrow buttons to make
adjustments to the option. You should use this method of adjusting the
sound settings if the audio output is in some way unusual.
4. Check the surround sound speaker wires and make sure they are secured to
the audio jacks on the back of the television. In addition, ensure that
the surround sound speakers are powered on.
If it does not work still. Contact your service provider. Thanks...
The TV is located in a small fitness center at our country club. The TV is working correctly again. I believe a member's grandchild came in and re-programmed it for us.
