We have a new oven and the heating element is located under the drip pan, i place aluminum foil to catch any dripping on the bottom of the pan (as I have always done, and it melted and stuck to the bottom of the pan ... how can I remove the melted aluminum from the pan?
(Wear a professional n95 mask and rubber gloves). Use a straight razor and scrape off as much foil as possible. Get a hold of Mercuric or sulfuric acid. BE CAREFUL not to spill anywhere, work close to a stainless steal sink. Poor a little in a small glass container and bring over stove porcelain surface. Pour the acid onto the foil and wait 3-4 minutes, use paper towel to wipe off the acid, and then a soapy wet rag. Repeat process until all foil is dissolved. Then wash surface thoroughly and repeatedly with a soapy dish towel. Once complete run water in the sink for 5 minutes till any possible remaining accid is flushed from the sink. The foil is gone and the porcelain is preserved. Works great! (Don't breathe the fumes and ventelate the area or move the stove outside)
Use "The Works Toilet Bowl Cleaner" to dissolve the foil. *Caution* when the cleaner is applied to the foil a chemical reaction occurs releasing some harmful fumes so please use outside or in a well ventilated area. I just did this to a Frigidaire oven I bought from Lowes at a discounted price. The previous owners bought it, did not read the owners manual or just disregarded the warnings on using foil in the oven and thought they would line the bottom pan with foil to help make it easier to clean (Good idea, but don't try it on the hidden element ovens). With the heating element being hidden under the drip pan the heat is hot enough to melt the foil and fuse it to the pan. Now most of the pans on these ovens are removable by just a couple of screws and I strongly recommend removing the pan when doing this. Squirt some Works toilet bowl cleaner on it in a well ventilated area and watch it go to work. It took about 15 minutes for it to dissolve all the foil on my oven, then I rinsed it clean and reinstalled it in the oven. The pan does have a slight discoloration on it, not from the cleaner but from the foil being melted onto the pan, if you choose you can buff this out. Most of the modern ovens have the ceramic coated drip pans in them so the Works toilet bowl cleaner will not harm them, unless you have scratched the finish off. Works Toilet bowl cleaner contains a fair amount of hydrochloric acid which is what makes this work so well.
I have the same problem. My stove is very new. I have tried everything I can think of but nothing is working. The aluminum foil is on top of the element cover in the oven. I have ordered a replacement. It will cost about 85.00 dollars plus tax plus delivery charge from Sears. That is very expensive. I wish I had the answer!!
Aluminum foil stuck at bottom of 2 year old Kenmore oven. How do I remove it ?
I have the same problem. My oven was put in on April 22, 09. I wanted to make a nice dinner, but didn't want any spills in my new oven. I put the foil down, as I have always done, to keep the bottom clean. Of course I just read the book and it says not to do that. I removed the foil, but some of it stuck in the center of the bottom of the oven. I called the GE Answer Number and they were not able to help me. They did say not to use my self-clean feature on the oven. Now, I'm not even sure if I can use the oven without making it worse. Thank goodness I have a double oven. Hopefully someone will find a solution for removing the foil. Gambergirl
aluminium foil stuck to new oven buttom-how to remove?
Did the same: put on bottom and now it's fused to the oven floor.
