SOURCE: wbr-2310 d-link
Follow these steps:
1.Type 192.168.1.1 in Internet Explorer.
2.You might have to put Admin password to access the router which is usually admin and password field blank.
3.Go to wireless setting and change the password.
SOURCE: D-Link 514 Secure Networking
To read the manual you will need Adobe Reader (free)
If needed click the Get Adobe Reader button on the following link
http://www.adobe.com
The DL-514 has several revisions use the pictures and the label on the router to get the revision for your router. Click on the picture and get the Product Manual (from the left column) -- you will need it to configure the router.
http://support.dlink.com/products/revision.asp?productid=DI%2D514
Looking at the page and manual for the A and B versions of this router which will not match yours WEP was originally supported adn WPA can be added with a firmware update on the page. -- you will need to tell me the revision for your router so I can gather the correct information for it to assist. Please report that in a comment to this issue.
WEP or WPA are kinda like passwords but you only enter them once into the router and once into each computer to access the network. The router has an administrative password that should also be set but that only stops people from changing the router configuration like we will do shortly.
I am looking forward to your response and pursuing the next steps in this process.
Once you get me that we will proceed to the next steps.
SOURCE: Lost password for access to D-Link WBR 2310 wireless router
Hold reset button in the back of the router. If that doesn't fully reset it, unplug it, hold the reset button for about 10seconds and plug it back it with the reset button held in for a further 5-10 seconds, release. Then should be back to factory settings.
SOURCE: dlink wbr-2310 router no wireless working
you have to change your channelk type in your wi fi router.
For that access your router with following link
http://192.168.1.1 or
http://192.168.0.1
if you have belkin router
http://192.168.2.1
type user name as "admin" and password is "admin" or blank or "password"
then go to wi fi ->advanced setup chang channel type 4 ,6 ,11
change chanel type 1 by 1 and check signal strength.
everyt time save settings and restart both computer and router after save settings.
Thanks for using fixya.
Please rate this solution if it helps.
SOURCE: D-Link wireless router & Ubee modem - which router ports
All routers will have a in for you modem, but your outlets wont matter what you use they are normally numbered 1-4 or 1-5. you can use any outlet and your pc will pic it up, they dont have to be in order through the ethernet.
